Surly LHT and Nice Rack Light Mounting
Old 10-16-10, 02:15 PM
jetbike
Playing with the traffic
jetbike's Avatar
Bikes: 2009 Colnago Primavera, Campy Chorus 11 speed, 1986 Colnago Master, C-Record, 2008 Surly LHT, 1930's Malvern Star 3-speed.
I have a well loved and well used Surly LHT, with Nice Racks. I have a new job that regularly means I have to ride in pitch darkness and so have built the Shimano DH-3N70 dyno-hub that has been sitting in my shed for 3 years into a wheel.
For practical and aesthetic reasons I want to mount the lights low on the front rack, rando-style. To reduce the shadow of the front wheel I will use two headlights. My question is this, do you know of any mounting system that will allow me to do this?
For illustration look here https://www.vanillabicycles.com/frames/randonee/2/
Also posted in the Long Distance forum
Many thanks
jetbike is offline
Old 10-16-10, 03:11 PM
bktourer1
bktourer1's Avatar
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 47 Post(s)
Liked 42 Times in 33 Posts
Take a look here: https://www.paulcomp.com/lightmounts.html
bktourer1 is offline
Old 10-16-10, 04:22 PM
TimeTravel_0
commuter
TimeTravel_0's Avatar
isnt there an eyelet right in front? I seem to recall there is...front and center. just use that with a single light.
edit: https://www.youtube.com/watch?v=r7vaQ...layer_embedded
TimeTravel_0 is offline
Old 10-16-10, 08:30 PM
jetbike
jetbike's Avatar
I was worried that it would just cast a huge shadow from the front tyre. Looking again it may not be a problem. I might just order it, mount it there and see how it goes.
jetbike is offline
Old 10-16-10, 11:13 PM
jwbnyc
Señor Wences
jwbnyc's Avatar
This is what I do with a Cygolite,
Topeak BarXtender,
and Paul Gino mount,
Works very well. I attach the Gino to the forward facing Nice rack brazeon.
Puts the light out forward of the bike.
jwbnyc is offline
Old 10-17-10, 12:09 AM
Bezalel
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
Topeak BarXtender,
So you attach the BarXtender to the Gino and mount your Cygolite to the BarXtender?
Bezalel is offline
Old 10-17-10, 06:07 AM
Tourist in MSN
Quoted: 3461 Post(s)
Liked 1,467 Times in 1,144 Posts
Piece of wood about the diameter of a broomstick handle about an inch long on a long bolt with a few nuts and lock washers. Photo shows a quick release light bracket installed on the wood. In this case the hole in the wood was drilled intentionally off-center so that the light could sit a bit lower and have a center of gravity lower than if the hole was drilled thru the center of teh wood.
Nice rack not needed for the mount used above, but if you only use the top of the rack and no panniers, this would work with the rack. On my Surly rack, I have cut strips of innertube rubber about 3/4 inch wide and the length that I needed that when I wrapped it around the front horizontal bar on the rack, it was about the diameter of a handlebar. Then put handlebar light mount on that. Wrap it tight so it grips the rack bar well and does not rotate. Sorry no photo of that option to attach.
File Type: jpg
Tourist in MSN is online now
Old 10-17-10, 08:31 AM
TimeTravel_0
commuter
you'll be fine. good luck.
Old 10-18-10, 03:38 PM
jwbnyc
Señor Wences
jwbnyc's Avatar
Yes.
Topeak BarXtender,
jwbnyc is offline
Fostergren
Bicycle Mechanics
4
04-30-15 10:29 PM
spierce7
Commuting
12
05-09-12 08:24 PM
shehasclass
Touring
7
04-06-12 11:06 AM
jetbike
2
10-25-10 01:09 PM
