Jens Voigt's Position...what do you think?
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Check out Jens Voigt's position in the drops below.
Do you guys run this much arm/knee overlap in the drops?
Granted he is riding the rivet to open his hip angle a bit but seem like his handlebar is in awfully close.
Who is to quibble with a top pro but what do you guys think?
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
Well, it obviously works for him. Having said that, he's been doing this since before the Wall came down, and back then the hot setup was considered to be to ride the smallest frame you could shoehorn yourself onto. It's possible that he got into that habit back then, and never broke himself of it.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6768 Post(s)
Liked 5,485 Times
You should eat a pound (or a half kilo if you swing that way) of hot asphalt for even questioning anything Jens Voight would do.
Lie down in shame and show your belly!
Artificial Member
Liked 5,485 Times
Now!
Artificial Member
Liked 5,485 Times
Don't make me get the newspaper.
NOW!
NOW!
Quoted: 551 Post(s)
Liked 277 Times
You don't tug on Superman's cape
You don't spit into the wind
You don't pull the mask off that old Lone Ranger
And you don't mess around with Jens
Bikes: Colnago C59 Italia Di2
I think.....you are obsessed. There is very little correlation between bike fits of one rider to the next, graphs have previously been posted which prove it - as much as 70mm difference in reach between riders of the same height. There are articles online that also talk about pros changing their stem lengths and seat heights between stages, cavendish is a notable example, big changes too. These guys ride how they are comfortable because fit is extremely personal. You simply can't measure someone and then set their bike up to some formula, if you do, it is unlikely to be optimal. My opinion of the photo, it looks like he's one of the most successful old blokes ever to ride a bike, you should learn from him rather than question or critique.
Other Worldly Member
Quoted: 194 Post(s)
Liked 136 Times
Why isn't this post in "Fitting your bike"?
Make ******* Grate Cheese Again
Artificial Member
Liked 5,485 Times
I think the question you should be asking is why doesn't your position on the bike match his...because clearly his position is correct. He's Jens Voigt for goodness sake.
Quoted: 194 Post(s)
Liked 136 Times
Jens doesn't get no stinkin' fit, the bike submits to him. If it had knees it would kneel.
I've got my own fit issues at the moment and have been reading some of Andy Pruitt's various columns and interviews.
Jens is named by Dr. Pruitt as an example of a Pro he has worked with but, who's position could be greatly improved, and, which remains less than ideal because of sponsorship constrants and other compromises.
Not all the pros are perfect examples of an ideal position. Every position is unique to the rider, their goals/requirements, flexibility, strength and the equipment choices available.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Quoted: 722 Post(s)
Liked 353 Times
I bet thst you would also have the bawls to comment on the set up of Eddy as well. BLASFEMER!!!!
fify
Bikes: 2017 Specilized Roubaix, 2012 Scott CR1 Team, Felt Z85
Quoted: 26 Post(s)
I feel its a little off but to question him about it would be like asking God why he mad bee's that sting
Campag4life,
Does this thread have any thing to do with Tromboneal's: https://www.bikeforums.net/showthread...k-Friend-s-Fit ?
Liked 10 Times
Jens power data from yesterday... I think he's doing ok on a brand new bike.. so it's probably set up about as good as he wants it.
https://www.trainingpeaks.com/av/DL3Q...5DMTKXBMFWBH5E
Bikes: Scott CR1 Team
Quoted: 20 Post(s)
Anyone who can put out 1200 watts, even for a few seconds, can be riding upside down while sucking his toes, for all I care. I can't even imagine that kind of power at 42 years old and 9,000 feet.
He only averaged 220 watts. Hell, I can do that on a Saturday group ride. What does Jens weigh? Maybe if I drop 40kg there's still hope for a pro career for me at 43 y.o.a.
