Tire pressure for MTB 29 , 2.25
Hi,
On my MTB, I have wtb Ranger tires, 29, 2.25.
Tire says pressure range, 35-55 psi.
What is the ideal psi for riding it on road and trails ?
Currently i am using 40,40 for both tires. Please suggest.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
You can go to youtube and search for "mountain bike tire pressure" to get more tips.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I don't know why manufactures bother with pressure recommendations like that. If you're riding trails, 40 is waaaay too high unless you're quite heavy. I'd think something in the 20s would be appropriate for most riders. You will feel benefits of lower pressure of you're set up tubeless.
for reference, I'm 160 pounds and using 29x2.3 tires (tubeless, naturally) on rocky terrain. Usually 20psi front and 24 or so rear, and mine are on the high side.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I'll elaborate. I consider roads to either be concrete, asphalt, or well packed crushed limestone you'll find on some MUPs. They're generally smooth. The idea of a higher tire pressure is to minimize the tire's rolling resistance, or the amount the tire deforms before rotating over the surface. On trails, rough gravel, and very poor roads, a lower pressure makes for a more comfortable faster ride than with higher pressure, because the obstacles on the trail can't deflect the tire as much when the tire is absorbing some of the deflection. For this reason, you'll likely have a pressure for cruising on pavement and smooth trails, while using a lower pressure for XC, dirt, gravel, etc.
I wouldn't go as low as tyrion suggested, but I'm using 26" clinchers. Tubeless setups can allow you to go lower because you don't have the risk of 'snakebite' punctures on obstacles. I find 42/45 sufficient for smooth rolling on pavement, and 33/35 has plenty of grip and float off road. Lots of guides recommend trial and error for off road pressures, dropping pressure until you can achieve the balance of suspension and grip you're looking for.
Thanks for suggestions.
I had some idea about tire pressures and to keep it low on trails than on the road but was getting confused as the manufacturer mentioned on tire, do not ride out of the recommended range on tire.
which is on the higher side. 35-55.
Thats why i was keeping it around 40 on road.
But didn't knw whats best on trails. I guess in the range of 35/38 shud b good on trails. Will try it out.
I am 175 pounds. 5'11
Quoted: 3242 Post(s)
Liked 2,089 Times
With tubes I used to run 35 psi on 26" wheels, with 2.1 tires. That was likely too high. On a 29" wheel with tubeless I run 22 F - 25 R. I'm 230 lbs.
Are you running tubes or tubeless? And did I miss How much road vs trail riding your doing? Also, are your riding hard pack dirt trails or technical trails? All this factors will make a difference. I currently ride at 22 front/ 25 rear on my full suspension bike, that’s with a 2.4 front tire and 2.3 rear. If I was running a 2.25 all around and running tubes I might bump it up.
perhaps a good option for your mixed riding is to bring a small hand pump and adjust pressures to the trail your on.
if it’s mostly hard trails I would keep running 40 at this time to reduce friction. You might bump them down to 32-35 on the trails for added traction. Just watch out for pinch flats.
Quoted: 1572 Post(s)
Liked 643 Times
Riding on roads and riding on trails are two different things. That's why there are so many different kinds of bikes and bike tires. "Trails" isn't really a very descriptive term either. There is a world of difference between a crushed limestone rail-trail conversion and hilly single track.
To me, part of the fun is figuring out for myself what the best combination of tires and air pressure is for wherever I happen to be riding. Technical single track = the lowest air pressure you can manage without getting repeated pinch flats. On paved roads, knobby tires need relatively high air pressure or they "squirm" and feel unsettling every time that you make a turn.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I am the same weight as you.
2.25” tires with tubes, on dirt I would try around 26 front, 30 rear. And then gradually lower until younger a pinch flat, then go up 2psi and call it good.
if you can’t deal with fixing. Flat to know how low you can go, then stick with 26/30.
For just pavement, i’d go 5-10 psi higher.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If I really like riding at say 25 psi but I got the occasional pinch flat I wouldn't raise the pressure to avoid those flats. I'm not going to ruin my ride quality and sacrifice traction to avoid something that might happen once or twice a year. If I rode where it's really rocky and pinch flats are a constant problem I'd go to bigger tires and/or tubeless. It's part of the game. You either have hard tires, ****ty ride quality, and not as much traction... or you have what you like. Flats happen, accept it and enjoy riding.
