Specialized Cranks and 11sp Campy
Old 11-03-09, 08:56 PM
varian72
Will the more narrow chain work with Specialized's cranks?
varian72 is offline
Old 11-03-09, 08:59 PM
Soil_Sampler
A little North of Hell
Quoted: 71 Post(s)
Liked 4 Times in 4 Posts
its the chainrings, not the cranks.
Soil_Sampler is offline
Old 11-04-09, 12:06 AM
varian72
Yeah, Yeah, but you're locked into Specialized chainrings so by default it's the crank as well.
varian72 is offline
Old 11-04-09, 01:06 AM
Soil_Sampler
Quoted: 71 Post(s)
fact
why? Specialized come in 110 and 130bcd spiders.
sram rings.
Old 11-04-09, 01:12 AM
Patriot
Faith-Vigilance-Service
Patriot's Avatar
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
I think it will work. But, that's just a guess.
I've used so-called 9s cranks on 10s chains before, and it works. So....?
President, OCP
--"Will you have some tea... at the theatre with me?"--
Patriot is offline
Old 11-04-09, 04:33 AM
Jay Olson
Jay Olson's Avatar
Bikes: Sarto Asola, Colnago EPS, Specialized Crux Sport E5
Quoted: 5 Post(s)
FSA makes chainrings for 110 and 130bcd spiders which are designed to work with Campy 11-speed drivetrains.
Jay Olson is offline
Old 11-04-09, 07:46 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1098 Post(s)
Liked 559 Times in 446 Posts
Most people who have converted to 11 speed, but use 10 speed cranks have not had a problem. Chainring spacing should be very close to the same for all modern 10 speed cranks. I used Chorus 10 with no problem.
The 11 speed chanirings are about .6mm narrower in spacing and the teeth are .1mm thinner.
DaveSSS is offline
Old 11-04-09, 08:14 AM
campyman099
Bikes: Tarmac Pro w/ SR 11
It works pretty good, but I would pickup some FSA 130mm BCD 11sp rings when you have the chance. They work better than the 10sp rings. You also may try calling Specialized and see if they make a 135bcd spider to use Campy rings instead.
campyman099 is offline
Old 11-04-09, 08:46 AM
DaveSSS
All Campy 11 rings only fit Campy cranks with one of the bolts located behind the crank arm. They won't quite work with a standard 5-bolt spider, even with the proper 135mm BCD. There's no bolt head countersink in the front side of one hole.
DaveSSS is offline
