Cannondale Synapse Carbon 4 or CAAD13 105
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Yes 15mm of stack height is significant enough to notice when it comes to bike fit. That is still easily accounted for between models with spacers, stem angle, and stem length.
Also, 15mm of stack height on a Synapse will not hold anyone back as a beginner. It really won't hold anyone back as an experienced enthusiast either since# as stated, a simple stem flip/spacer swap will get bars in the same effective spot.
As far as the OP, you may have noticed I did ask him for missing information and he still has yet to reply.
A common problem with 'which bike should I get' threads is there often isn't enough detail. Here is yet another example since the OP doesn't say what frame size they need.
I provided a screen shot of the largest size for each bike and cited the geometry differences as well as similarities. My comments are accurate based on the info provided and info I know of. The bikes, in the size I specifically references, really are not drastically different. They are subtly different in a few ways and are identical in more ways than different, actually.
If more info is given, better advice can be given.
...well some better advice will be given. I'm sure there wills till be some who just talk about cannondale from 30 years ago and lament offShoring production# as oft hat has anything to do with right here and right now.
If the fit of the optimo is better than perhaps the CAAD13 is the way to go down.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Yes, to a degree. Though as someone with back problems who is always trying to get up higher, there is only so far you can go - especially now that just about all bikes have carbon steerers that prohibit the use of extenders and also have limits on the number of spacers you can put under the stem.
The OP didn't mention any flexibility issues though and the examples I cited simply don't have enough variance in geometry to say one will be noticeably better than the other for a rider with pain or limited mobility. Frankly, neither seems ideal for that.
When compared to options across the categories, a Synapse is pretty aggressive on geometry compared to a Domaine, for example. This is why I advised the OP to ignore the marketing label and focus on actual geometry.
In the OP's case, they want a bike that won't hold them back. That, to me, means no back pain or other limitations. In that case, a Synapse stem being lowered 15mm and adjusted in length to match the stock CAAD setup is absolutely possible. Or if the OP needs a larger frame, then the differences are even smaller(see the geometry screenshot) and even more easily matched.
Simply flipping a 100mm long 6deg stem so it's -6 results in 20mm of bar drop. That alone, a stem flip, more than accounts for the stack height difference between models in the smaller size.
My initial point was to try and show that neither bike is going to hold the OP back and that it's largely a waste to focus on the idea that 'endurance' is slower or more sluggish feeling(since steering and chainstay are either identical or so similar it won't be noticed).
Sunshine
Liked 7,491 Times
Hi I didn’t think that size is important. I’m 5’7, but I’m looking at 51cm for CAAD13 and 48 for Synapse. The Synapse just felt huge compared to an optimo 51 I have, so thought about downsizing.
What model year is your Optimo?
What don't you like about your Optimo that you hope to change with a new bike?
These are all helpful questions to have answers to.
Likes For mstateglfr:
Sock Puppet
Liked 863 Times
For sure- someone with back problems may need a different fit and gravitate to the option with more stack and less reach.
the Optimo bike is amazing, loved everything about it. Just a lingering thought, if I looked cooler and would I be faster on a nicer/lighter bike. I was just curious what the next realm of upgrades would get me for an extra 1000 budget I have. I’m having a blast riding and an upgrade isn’t necessary. Just wanted something nice for myself
Sunshine
Liked 7,491 Times
the Optimo 2, is the 2022 model, all the bikes mention are brand new and latest model.
I figured you were coming to this with no road bike experience, but you have a caad right now.
OK, pretty sure I'm out after this as getting useful info has been difficult and you already have a bike to compare others to.
Below is a caad optimo in 51, a caad 13 in 51, and a Synapse in 48.
Once more- your current bike and the two you are asking about will all be more capable than what you currently need or will likely need in the future. None will hold you back and all can be set up to be essentially the same fit.
Based on geometry below, the Synapse won't feel sluggish or slow steering compared to the Optimo or 13.
Hey everyone,
After seeing the chart provided by the friend above, was down sizing the synapse for 51 to 48 the correct decision to reach the measurements of my beloved Optimo 2?
The issue now is that CAAD13 is the bigger bike among the 3 bikes, Optimo, Synapse and CAAD13.
the Synapse 51 was a completed nightmare, it felt like a 53-54 road bike. I was just too stretched out and don’t want to run a risk of that. The Optimo, although 51, for some reason it works perfectly.
thanks every one for their help! Still haven’t figured out the best, bike, but getting closer with all the considerations and perspectives
Hey everyone,
This is odd, the Synapse 51 should be close to identical to the Optimo 51 fit-wise. Synapse has a 0,2 mm longer reach but even that is probably offset by the much slacker head angle, which brings the stem a hair closer. There must have been a difference in setup that caused you to feel that much longer on the Synapse you tried; stem length, handlebar geometry or saddle fore/aft.
If I were you, I would get myself some nice wheels for the Optimo and be done with it. It is a serious road bike to me. The Synapse might not even be that much lighter than the Optimo depending on the models. With all that money you could upgrade the heck out of that Optimo and make it much lighter and more aero.
Sock Puppet
Liked 863 Times
Looking at specs for the Optimo, it is outfitted with Vittoria Zaffiro tires which are pretty entry level. You will most likely feel a difference getting more supple tires like the Vittoria Rubinos or even Corsas if you can afford them. I know that's not as blingy as a new bike or even a new set of wheels, but much less expensive.
Likes For Lombard:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 569 Post(s)
Liked 772 Times
Its hearing these opinions, that give me perspectives that I don’t have as a new rider. There is a difference besides the material and group set, it’s something I can’t put my finger on. But for some reason CAAD13 is preferred by many others. It’s just hearing more reason why.
Seems like the CAAD13 model is just above the Synapse. I understand that it may be more different purposes but I just want a good riding experience
You are looking at a cheap(er), lower tier carbon frame, vs a top of the line aluminum frame. Personally, I will take the top of the line aluminum over cheap carbon every time.
Ride both and see... I have 3 bikes, two carbon (one cheap open mold and one mid grade Giant) and an aluminum frame (Emonda) - the Emonda is better in every way compared to the CF bikes. Its stiffer where its needed, smoother and has better power transfer - the bike also has a better overall feel.
Sock Puppet
Liked 863 Times
I would not consider the Synapse a lower tier carbon frame. The main things that make a bike more of less expensive are the components on it.
Quoted: 569 Post(s)
Liked 772 Times
^^^This. Frame geometry has a lot more to do with ride quality than frame material. Any frame material can be made to have any ride quality.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
In the prior two generations, there were two versions of the CF Synapse frame: regular and Hi-Mod (i.e., higher modulus carbon fibers, so lighter). But I have not seen this distinction in the current generation. Regardless, as Lombard said, I would not consider any version of the CF Synapse "a cheap(er), lower tier carbon frame."
Quoted: 569 Post(s)
Liked 772 Times
Then what is your basis for calling it "a cheap(er), lower tier carbon frame"?
If they no longer do this - then I have no basis. That is why I asked...
My statement, and my personal opinion is - the high teir, top spec aluminum frames can be very close to equal, or better, than the same manufactures lower tier versions of their CF frames. Many times you pay 1k+ more and get nothing in terms of performance, ride quality, even weight. And that 1k more typically gets you a lessor groupset.
Trek for example - Emonda SL5 (low tier CF) vs ALR5 (high tier aluminum) - in terms of the Trek lineup
19.55# vs 19.92#
$1050 more for the CF - $1050 for a few ounces of weight savings
Many people will say the ALR frame is as good or even better that the SL
The only reason for my point was to answer the question - why do some people prefer the CAAD vs the Synapse, and is the higher price with lower groupset "worth it"
IMHO - it's not worth it.
Liked 1,471 Times
My basis, if they still make two grades of frames, is that the lower grade frame is lower tier than the higher grade frame. So, it's both cheaper, and lower tier than the higher grade.
19.55# vs 19.92#
19.55# vs 19.92#
2. Makes no sense: Synapse Carbon vs. CAAD13. The current Synapse is an endurance bike which is marketed as more of a lifestyle bike and not really comparable to a race bike.
3. Makes more sense: SuperSix EVO vs. CAAD13. See #1.
Sunshine
Liked 7,491 Times
In reality, that 'lower grade' frame can still be exponentially better than almost anything else on the market.
Its disingenuous to just claim a frame that isnt the highest tier frame is therefore a low grade frame.
Quoted: 569 Post(s)
Liked 772 Times
1. Makes total sense: Emonda SL 5 vs. Emonda ALR5. Both are race bikes have the same geometry and the same purpose.
And, I was just responding to the OP's "cons" list. He listed aluminum as a con - I was responding to how it may not be a con.
Sunshine
Liked 7,491 Times
Trail measurement is the same, so they will feel the same at the front end when steering. Chainstay length is so close that the difference is not even perceptible when riding. Seat tube angles will easily allow the rider to get an identical saddle position on both bikes. Wheelbase length is the same. Front Center measurement is nearly identical. BB drop is basically the same, so the bikes will feel the same for someone 'sitting on vs sitting in' the bikes.
How is that Synapse not really comparable to a race bike, when the CAAD13 is a race bike?
Will the specs of the Synapse allow me to travel on light gravel with 700C tires that it comes stocked with? If it can allow more versatility, I can trade it for the “speed” which the CAAD13 is made for. I can lose a bit of zoom zoom, the trade off is to go off light gravel a bit it may be a consideration.
The previous guy made a valid point, Top Aluminum vs Low grade Carbon. I’m frankly not sure if the technology has all caught up yet . Is it fair analogy to a decked out sports mod Toyota Corolla (synapse), or Toyota Base Camery (CAAD13)? Given that I would choose the Camery, better engine and higher tier.
thanks
Cannondale recently released Lab71 bikes. These frames weigh a handful of grams less than the 'regular' frames. By your logic, now that there are two grades of frame, the lower grade frame is a lower tier also.
based on that, if Alum prevails, the obvious choice will be CAAD, if Carbons worth it, the Synapse will win.
Sock Puppet
Liked 863 Times
As has been pointed out before, I don't think you would go wrong with either one of these bikes you're considering. Nor do I think you will get anything better than the Optimo you already have.
They used to. Awhile back, Cannondale had what they called "hi-mod" carbon which supposedly weighed less. Being the cheap a$$ that I am, I decided it wasn't worth the extra $2,000 for the hi-mod version of the bike and went with the "regular mod" version of the 2014 Synapse Carbon, which feels plenty stiff - a whole lot stiffer than carbon frames of less than a decade before.
