DIY Heated Liner Gloves
I made a heated glove liner to address the 3 minor gripes I have with the heated gloves I bought last year. Battery placement on the wrist interfering with glove fit, the heating elements being on the back of the hand, and the glove being a little bulky.
While I was at it I made an Instructable if anyone is interested in how I made them: https://www.instructables.com/id/Heated-Glove-Liners/
The most expensive part of this project would be the batteries / charger. In my case I can just use the batteries from my other gloves. But without the controller I will have just 1 heat setting. I have a new respect for people that build tutorials, it is fairly time consuming taking pictures while you are doing something, taking notes, editing the images, then creating a coherent set of instructions.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Why did you not like the heating elements on the back of the hand?
My understanding is that the back of the hand is where there is greater blood flow and so more opportunity for heat transfer. Was this not the case for you?
I'm not trying to challenge but sincerely interested.
-Tim-
-Tim-
-Tim-
-Tim-
Also it seems like grasping anything with your typical synthetic glove squishes the insulation flat on the palm side wiping out a good deal of its insulating capabilities. I have wool gloves that work great since they don't compress much, but my hands freeze in larger gauntlets.
- Soli Deo Gloria -
Liked 736 Times
Ah, makes sense, Thanks.
I've not tried wool gloves but have a pair of gloves made from Polartec Powerwool. Amazing stuff.
Thought about this thread last night when I rode at 30° with chemical warmers in my Swany gauntlet gloves.
-Tim-
-Tim-
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Hmmm... this is stimulating some thought - sparking electrical currents between the last two brains cells I got left...
My snowblower has heated grips. Has anyone here tried heated grips? What sort of battery would you need for that?
Great job! Hey, how long did your battery last?
The carbon rope material I used can get very toasty when using a 12 volt battery, 92 C at a length of 80 cm. The temperature varies with voltage, length and how much of the rope you use. The rope is made of 12 smaller ropes, so for my gloves I only used 2 of the 12 ropes in addition to the lower voltage.
Bikes: 2007 Specialized Tricross Sport
Quoted: 34 Post(s)
I made a second Instructable for toe warmers using the same material. https://www.instructables.com/id/Ins...-Heating-Pads/
It is considerably easier to make than the gloves, no glue, no silicone, but getting the loops down can be a little tricky.
I took another crack at the glove design and made it a much easier project. Double sided fabric tape instead of glue / silicone, everything is inside the glove under a few pieces of polyester / spandex fabric. Also have the option of putting the finger heat on the front or back, thumb has both.
https://www.instructables.com/id/Hea...-Liners-Ver-2/
I improved and simplified the design of my heated glove tutorial. The wire to carbon connection was the weak point in the old design. I came up with a method to make the connection much stronger and much smaller.
https://www.instructables.com/Heated-Gloves-Version-3/
Likes For gecho:
Quoted: 5224 Post(s)
Liked 3,584 Times
After making the 3rd version of my heated gloves I kind of regretted using a heavier glove, so around Christmas I made another pair that would fit inside my wool gloves. These ones are a bit different in that I can run both gloves off a single USB-C power bank using the 9V alternate voltage mode. I figured I should make another tutorial otherwise I'd forget how to make them the next time I need to make a pair.
https://www.instructables.com/Heated...B-C-Optimized/
How do they fare in the wet?
I tried a few things like this but have now settled for silver threaded liners, ice climbing gloves and above all neoprene covers for my shifters that my gloved hands go into. These also keep rain and salt out of the shifter mechanisms.
If the gloves stay dry, they are much much warmer.
They work pretty good when they are damp. My hands often end up sweating during a long winter ride no matter what I do. Which likely contributes a lot to my hands being cold on the way home. The active heat helps offset the accelerated heat transfer.
A few times I've looked for another source of the carbon fiber heat rope but never found one. With the supplier in Russia they can't accept paypal for the foreseeable future. So I made another effort to find a different source, but zilch. Which is really strange, I figured all the heating products coming out of China would use something similar but Aliexpress only has the finished products and no source of the raw carbon. The seller's instructables name is Shenzhen, which in itself suggests that he might source it from China but maybe it is manufactured in Russia. For a direct replacement to work with my tutorial I'd need something with a resistance of 20 ohms per meter.
