'72 PX-10 rehab/650b conversion
Quoted: 1088 Post(s)
Liked 1,205 Times
In my experience, corks aren't compliant enough to allow the flexibility a spring would. Once it is compressed, it is pretty rigid, and it needs to be solidly secured to avoid rattles. I still like to use them as fender spacers, but I go in not expecting it to solve the need-to-deflate-to-remove issue.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I was very close to doing this, but decided to live with mounting with a nylon spacer and having to deflate for now. Truth is that if/when things are well dialed in I don't expect to be taking the rear wheel off/on very often, so having to pump isn't that big of a deal.
Likes For ThermionicScott:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times
That's fair! I have other bikes on which I need to deflate a tire to get the wheel out of the bike (if it wasn't already flat), but for this one, I stubbornly made it a goal not to need to. If I lived closer to @gugie, I'd probably send him the frame to replace the dropouts with verticals!
More recently I just hacked off half of the lower portion of the dropouts. Customer wanted the wheel all the way back in the horizontals anyway. That's easily a DIY solution with a hacksaw and file.
Likes For gugie:
Liked 5,801 Times
Part of my Gugificazione 650b treatment is to remove the brake and chain stay bridges and make new ones to give a good fenderline without spacers and also gt the wheel out without having to deflate. On horiziontal dropouts the chainstay bridge gives a bit more clearance than the brake (now a fender) bridge, but it's typically only noticeable if I point it out. Of course, that only makes sense if you're doing a lot more framework since it requires a repaint/powder coat.
Likes For gugie:
Liked 2,568 Times
I've done it twice. One frame I left the seat stays on. It was a real pain in the a$$ to fit it up properly. Next one I removed the seat stays, brazed in new dropouts, then replaced the seat stays. A lot easier, however it was still a lot of work.
I have filed small amounts away from the forward lower ends of my horizontal dropouts, but didn't know if it was kosher enough to mention.
Liked 5,801 Times
That makes sense -- I don't see much dropout-swapping apart from Yellow Jersey's page, and I can only imagine what a pain it is to line up right.
Ignore the dingus in the back.
Likes For gugie:
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Well, while we're on the subject of dropouts........ No matter how tightly I crank down the QR skewer on the rear axle, if I stand up and hammer up a steep incline the DS pulls forward and the tire rubs the left chainstay (sometimes enough to nearly stop the wheel...). The chromed Simples dropouts seem particularly 'slippery'. Anyone got a clever/easy/cheap solution to this?
Quoted: 761 Post(s)
Liked 1,563 Times
I've used corks before. They compress enough on marginal cases. The VO Spring Thingie compresses a lot more, but it also rattles a lot, whereas the cork solution doesn't.
Liked 2,568 Times
RUSA #7498
Liked 5,801 Times
Not yet. But many others have successfully put 650b x 42 wheels on them, and that's 90% of the battle.
Likes For gugie:
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
Quoted: 761 Post(s)
Liked 1,563 Times
What do the VO skewers and hub locknuts look like? A lot of newer options have smooth faces, while older ones were rough (knurled the right word?) and had more "bite" for this situation. I bumped a rear tire into a seat tube on my Bianchi - test riding it and standing/stomping up a hill with some DT Swiss wheels I had laying around (which had smooth faces). Lucky I caught myself as all of a sudden the rear tire wouldn't move, for some reason I'd popped on some pedals with cages and straps for the test ride.
Quoted: 761 Post(s)
Liked 1,563 Times
....just did- DO is 6+ mm thick and there's about 5mm of axle, so alas that isn't the issue.
Quoted: 761 Post(s)
Liked 1,563 Times
All the braze-on goodies like direct-mount Raids, bottle-cage bosses, seat-stay pump pegs sure would be cool on a PX-10!
Quoted: 3811 Post(s)
Liked 6,707 Times
Another PX-10 option is the 650a conversion!
Likes For nlerner:
You need some elastic cords or paracord retaining straps for your water bottles which are anchored at the base and loop up and around the necks of the bottles to hold them down and in the carrier.
Likes For Bad Lag:
Quoted: 761 Post(s)
Liked 1,563 Times
The King Iris cages are quite tight and so far I haven't had a problem with the bottles rattling of coming out. That definitely wasn't the case with the V-O Moderniste cages I originally had on there- far too flexible and loose (one of my bottles has some nice dings and road-rash now....)!
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Winking owl from Aldi has synthetic corks that are terrific. The wine is 3$/bottle. Go crazy man.
Liked 2,568 Times
ambulatory senior
Liked 3,661 Times
That's an excellent looking bike.
Likes For 52telecaster:
Quoted: 761 Post(s)
Liked 1,563 Times
Yeah, it's a very stylish looking cage, but doesn't seem up for the rough stuff..
Quoted: 1858 Post(s)
Liked 664 Times
I've paid a lot of attention to this on the Witcomb wheels. I shortened the axles (new replacements, due to bent axles) by trial and error. On the NDS stamped dropout I settled on between 1.5 and 2 mm clear space. On the DS there is also a claw to mount the derailleur, so I allowed a full 2.5 mm (dropouts are 3 mm thick). Same values on the front wheel. The front wheel is holding the fork very tightly. It's really not ready to ride, so I can't really tell yet if it's tight enough, but the front wheel QR clamping is very promising. I also think the quality of the QRs is important, in terms of knurls and teeth that bite, and a clamping lever that feels solid. I think the traditional Campagnolo designs are among the most solid, but one of the ones I'm installing is a Joy-tech, and the other is a modern all-steel design, which was nameless on Amazon. But it is holding the front wheel solidly.
Quoted: 761 Post(s)
Liked 1,563 Times
A bit of follow-up re the slipping axle/QR issue.... I took a dremel to the inside of the original Simplex QR skewer nut and added some slightly deeper 'knurling' cuts which seems to have helped. Still have to really crank the QR down, and haven't been on another serious long, standing-on-the-pedals uphill grind, but so far it holds. Kind of interesting that the way the inside of the nut is shaped, concave with a really pretty thin ring of contact, sort of seems like more surface area would've been a more stable design? Unless maybe less surface area causes it to 'dig in' more...
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 639 Times
I'm curious about how to measure to determine if such wheels fit a frame; I presume you need (a) the overall greatest diameter of the wheel/tire combo from axle centerline to furthest point, and (b) at how many mm from the axle centerline is the widest point on the tire, to clear the chain stays. Is this knowable anywhere?
I have a friend that has long since "gone carbon" but he inherited his father's bike; I have not seen it in many years but I recall it's a full-Campy-except-brakes Raleigh, and I showed him this topic and he might be interested in such a conversion.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 761 Post(s)
Liked 1,563 Times
A 650B wheel will most definitely fit a frame made for 700c, as the 650B is a smaller diameter. The question is how much extra clearance for wide tires will it give you, and is it enough to be worth it. And what will you need to do as far as brakes. It gets a little more complicated as the width of tire you run will determine where exactly the widest point will be, as well as your overall diameter.
I've got to run now, but I'll see if I can find the numbers..... But I believe I determined that with 650B x 42 tires the widest point was about 303mm from the center of the wheel..... And I think the outer edge of 700c wheel is more or less where the widest point with a 650bx42 tire will be....
