Spray.bike?
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Quoted: 3464 Post(s)
Liked 2,829 Times
I reviewed all the info I could find a while ago including their tech articles.
on a carbon frame where a matt finish is desired, ok.
on a lugged steel frame where an initial primer / sealer would be best, I am concerned.
the toughness and long term durability is undetermined. Not stated effectively is the temp and humidity range the coating performs best in. Notice I wrote coating, not paint.
Likes For repechage:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Never used it. It looks nice in a photo with talented users, though photos of anything from a distance always look better than real life.
From my extensive research last year prior to painting a couple bikes..it looks good in the short term and is easy to use. If you want high gloss..you won't get it. Long term, with normal bike use,...meh...as far as durability.
For $8 more a can, with no shipping, you can use custom-filled rattle can auto paints and two-part clears**. Clears can be matte to super high gloss. Colors..probably a thousand or more to choose from, from solid base coats to metallics to pearls to candies (look at any can anywhere..the paint is available). I figured, as long as I'm going through the time and effort to paint a bike..might as well take a long-term approach and get the best appearance too.
Search for a local auto parts store that supplies local painters with paint. They can mix up and load rattle cans in a few minutes.
**Auto paints are really easy to use and are very fast to work with, but you do need a good respirator when spraying..less than $50.
framebuilder
Likes For Doug Fattic:
Quoted: 634 Post(s)
Liked 444 Times
I painted a mountain bike frame during lockdown. I was painting over an existing factory paint job. I did a lot of sanding prep, followed the spray.bike instructions, and took my time. I was happy with the result. Agreed with the above comment that it's not a very glossy finish. It's more of a powder. I used one of their sparkle clear coats as the final coat, which was fun. It added some glossiness. Those cool colors and finishes, ease of use and bike specificness are their selling point. It sounds like you can get a more traditional finish using the automotive options above.
As far as durability, I can't really tell you. Hazetguy's post above should have more info about that. So far it's held up well, but this was a bike for the girlfriend that doesn't get a ton of miles, bike rack parking, or other things that are hard on finishes.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
I have painted 3 bikes with spray.bike products.
- the fluro colors are 'hairy' and easily messed up.
- prep is 90% of the process.
- compact the paint with a cloth or paper towel as instructed. It smooths everything out.
- durability has been fantastic. It doesn't chip easily when applied properly.
- it will not sit as smoothly as wet paint. Just don't hope for that.
