Snow Goggles
Unracer Cyclist
Bikes: Huffy
Snow Goggles
I am getting tired of my goggles getting foggy after few minutes of riding. I bough the Spy anti-fogging snow goggles. They do still get foggy what are you guys using? For the last two month, when I start my commute in the morning the weather is below zero. So I like to have some eyes protection. Any suggestion?
Jedi Master
My goggles don't fog up unless I cover my mouth and nose and breathe into them. I use Smith Cascades which are just about the cheapest goggles you can get.
Bikes: various strays, mongrels, and old junk.
Still working on this problem myself. My current thing I am trying is a paif of those sunglasses from Walmart that go over my perscription glasses - It was about -13C this morning, so not quite down do zero for you MI types, and they were fine - but my mouth and nose were not covered either.
Working ....
Working ....
Unracer Cyclist
Bikes: Huffy
I know covering my mouth and nose had something to do, but I never thought on being directly the cause of my goggles fogging. I will have to try to wear them goggles without my full face mask which I have been wearing all this season.
I am not comfortable breathing all that cold air into my system though. It can't be good for you, although I don't know for sure.
Quoted: 800 Post(s)
Liked 218 Times
BTW, to the OP, TroN0074 of Michigan USA, you can trust me because I’m from Michigan too (East Side of Detroit).
Solved this with my combo balaclava + dust mask + double lens goggles. No more fog even at stops, red lights...
Quoted: 800 Post(s)
Liked 218 Times
My usual question, "How cold and how far do you ride?". After all, according to your given Location, "6367 km away from the center of the Earth," the climate is ambiguous.
The Earth isn't a perfect sphere so this radius gives more or less my lattitude (i live in Canada).
Quoted: 800 Post(s)
Liked 218 Times
I have often posted that for any evaluation of winter gear, the poster should specify temperature and distance (as a function of time). One post once suggested that a "cold" ride is one where the water bottle freezes solid; a function of temperature and time. For my 14 miles that occurs at about 15º F or less (-9.4º C).
Unracer Cyclist
Bikes: Huffy
Thank you. My commute is 9 Miles one way, I leave home by 6:00 AM, usually after 4 miles of the ride my goggles are completely fogged. I thought about combining full face mask with a dust mask too. Now that is March hope the weather wont go below zero anymore.
Another thing I thought is to use agaiter neck with the goggles instead of the mask. I check that out and report back. Thank you again, I really appreciate it.
@Jim from Boston - Maybe we will ride together sometime and grab a drink. I am planning on join some of the rides organized by the community in Detroit, They have some Slow Roll Detroit events planned for this year that sound good. I am in Lansing but I have been wanting to take part in a big group ride.
Quoted: 800 Post(s)
Liked 218 Times
Regarding mask and neck gaiter, I posted this about riding at 1º last week:
Helmet, woolen cap, face mask held in place with thin nylon balaclava, and neck gaiter. Since I wear prescription eyeglasses and overlying goggles, I have literally solved the fogging problem by suspending the wide-open safety goggles as a wind screen from the blue surgical scrub cap by a Velcro strip attached to the nosepiece of the goggles. The rigid goggle earpieces also provide a support for my two rearview mirrors…
Jedi Master
there are several products on the market to address this problem
nofog
castle x
cold avenger
I personally just use a balaclava that covers my mouth but not my nose.
nofog
castle x
cold avenger
Bikes: Bacchetta Giro 20, Trek 7000, old Huffy MTB, and a few others
Quoted: 21 Post(s)
I use the FogEvader I got from Amazon in it's place. https://www.amazon.com/R-U-Outside-He.../dp/B0043XRF6W
That still doesn't solve my issues of fogged glasses when my face heats up, but adequate ventilation helps.
Jedi Master
I threw out the mask for my cold avenger a couple of weeks ago after never getting it to work well.
I use the FogEvader I got from Amazon in it's place. Amazon.com: R.U. Outside Helmet Fog Evader Face Mask: Automotive
This one from Klim gets good reviews from the snowmobilers. Seems like they would know a thing or two about keeping comfortable in cold weather.
Quoted: 800 Post(s)
Liked 218 Times
Unracer Cyclist
Bikes: Huffy
This is the one I have Robot Check
It has good reviews but they still fogg.
I think ricohman uses his on conbination with hat + neck warmer not full face mask for what I see on the picture.
I will try that.
I will try that.
Quoted: 21 Post(s)
Editted to add: I may have a high and / or steep nose bridge, I'm not sure.
Liked 6 Times
I will try that.
I will try that.
Jedi Master
I returned that one. It would not sit on my nose right and my glasses fogged immediately. My ski goggle *kind of* held it down. If I didn't have glasses it might have been OK. Prescription eyewear seems to be the downfall of most of the face masks I try. I can wear them with ski goggles no problem, but adding the second layer of eyewear is a problem.
Quoted: 21 Post(s)
In between, I wear this:
Amazon.com: Seirus Innovation Men's Ultra Clava: Sports & Outdoors
Breathing technique is important on that last one (if I hold my mouth wrong I can fog, I have to create a "seal" with my top lip). I use safety glasses to shield the wind too.
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
As i have different goggles i see how good goggles makes a difference. When i don't use my technique my sunglasses fog in less than 5 minutes after i start riding. My double lens goggles will start fogging after about 20min riding.
https://www.amazon.com/Pyramex-I-Force-Sporty-Silver-Mirror/dp/B006WPSEVO/ref=sr_1_19?s=sporting-goods&ie=UTF8&qid=1425616642&sr=1-19#customerReviews
https://www.safetyglassesusa.com/goggles1.html
Liked 6 Times
Fan?
I don't know about the eye glasses though.
I wear them next to my face or over my balaclava.
Jedi Master
