Unusual derailleur lever mount?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 649 Times
Anyone ever seen or used one of these?
In someone else's WTB topic, someone's post included a link to an overseas parts seller and I was curious and nosed around -- and saw this: LEVER MOUNT
Other than some 1970's Schwinn Varsity/Continental/Suburban bikes, never saw a lever mounted to the headset before. What would this look like in use? Depending on whose lever it uses, might be a fun install on a vintage bike converted to upright bars and a 1x shift arrangement?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
interesting. My wild guess is it was a 5 sod Mixtie thing?
velobase pic.
velobase pic.
Sugar "Kane" Kowalczyk
Quoted: 2588 Post(s)
Liked 4,827 Times
Looks like your basic stem shifter with mount. This one's a single lever setup, probably for a 5-speeder as noted above by @Bianchigirll - there were also dual lever setups which would give you ten speeds. I had one of the latter on my '78 Schwinn Traveler III.
DD
DD
Quoted: 987 Post(s)
Liked 649 Times
110% -- except it won't mount to a stem. Looks like someone in Metal Shop Class tack welded a shifter boss to one of those headlamp brackets that I've seen. Actually, kind of a neat place to mount a shifter. I'll take a wild guess that it mounts UP from the keyed-washer part, rather than DOWN?
Liked 4,827 Times
It probably was tack-welded, but by a manufacturer. It was commonly used on lesser-quality 5 and 10 speed bikes for a long time. You could probably mount it upside down or right side up and it would work; one way would result in the lever being higher, the other lower.
EDIT: And, of course, depending on where the fork slot is, either on the right or left side of the stem.
DD
Likes For Drillium Dude:
Bianchi Goddess
Liked 2,934 Times
I found this interesting looking setup also
Liked 4,827 Times
That absolutely, positively has to be something Rivendell keeps in stock - hell, they probably invented it
DD
DD
Bianchi Goddess
Liked 2,934 Times
DD
DD
Bianchi Goddess
Liked 2,934 Times
It makes your 66cm frame look like a Mini Velo
Likes For Bianchigirll:
Liked 4,827 Times
DD
Liked 4,827 Times
This is what we do in the winter when the riding is scarce: argue over semantics (among other things)
The gear levers end up residing next to the stem in both applications; hence, stem shifters. This ain't rocket science. Let's move on, shall we?
DD
DD
Because they clearly are different methods of mounting shifters, so why call them the same thing?
This is the topic of this thread. Why try to shut down the conversation when people supply opposing views?
Liked 4,827 Times
Not trying to "shut down" anything - I'm saying we're veering waaaaaaay off-topic. The OP asked it the particular mount was something anyone here had seen before. A number of posts since then have confirmed that, yes, it was a common item to mount what has been known for many, many years as "stem mounted shifters". Seriously, have you ever heard the term "headset mounted shifters"?
TL/DR: The OP's question has been answered.
DD
SE Wis
Quoted: 2750 Post(s)
Liked 3,406 Times
Did I accidentally click on P & R?
Quoted: 3811 Post(s)
Liked 6,721 Times
I’m just troubled that the OP called it a “derailleur lever.”
Likes For nlerner:
Quoted: 987 Post(s)
Liked 649 Times
For one of my upcoming projects I hope to use a 7/8 speed IGH and I have not decided where the shifter would go -- this might be an interesting option.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 537 Post(s)
Liked 1,017 Times
Likes For Pompiere:
Quoted: 569 Post(s)
Liked 594 Times
Wish I had kept this one, but looked dangerous after witnessing an unfortunate cyclist car-doored. An IRD quill stem shifter mount.
Liked 4,827 Times
Ouch.
DD
