Wahoo and Cycleops training software question
Looking at upgrading my 18 year old Fluid2 with a smart trainer and the Kickr snap and Cycleops M2 are my top picks right now. I want to stay with wheel on because I have both Campy and Shimano drivetrains and don't want to deal with swapping cassettes in a direct drive trainer so these are the top picks.
I am finding information on what free software comes with the trainers confusing at best. For Cycleops, I see people mentioning Virtualtraining that comes free, but there is nothing in the app store for apple matching this. Did Virtual training become Rouvy at some point? If so isn't Rouvy a paid subscription so I would have to pay to do simple spin down calibration? Or am I missing something.
For Wahoo it seems less confusing and looks like there is a wahoo fitness app in the app store that would work with the snap trainer.
I plan on trying out Zwift, Rouvy and trainerroad. Probably going to go with something like trainerroad because I would rather watch recorded races from nbc sports and whatnot rather than watching virtual stuff of me. I will be using my iphone to control it and screen mirror with a lightning to hdmi to the big tv if I decide I do lift zwift or Rouvy type software.
What software do you use if you have a cycleops or wahoo trainer? What is available for free that comes with each?
Quoted: 942 Post(s)
Liked 527 Times
I can't speak to the others, but Wahoo does have a fitness app, but if you have an Elemnt or Elemnt Bolt, it will connect and control your smart trainer (targeted watts, resistance, level, erg mode, etc.). It will also allow you to virtually ride any route that you have created in RideWithGPS (for example). None of these are like Zwift or FulGaz where you are in a virtual environment (on TV). I find myself using Zwift less and less and using my Elemnt Bolt more and more while watching something on TV I am interested in, such as GCN or GCN Tech, etc....
HarborBandS
Quoted: 266 Post(s)
Liked 104 Times
I'm also in the market for a Wahoo smart trainer, but am undecided between the Kickr Snap (wheel on) and the Kickr Core (direct drive). I had a wheel-on trainer many years ago, and it really wore down my rear tire and created a lot of black rubber dust. Are the newer trainers any better for this? Do most people use separate "trainer wheels" to avoid wear on their nicer road tires?
Are there other advantages to the direct drive trainers other than wheel wear and tear? Is the road feel significantly different?
Quoted: 276 Post(s)
Liked 6 Times
Also no, you do not need to purchase any type of rouvey subscription to calibrate. There is a phone and computer app for Rovey, you can use it for spin down calibrations, a 1 hour free ride, and firmware updates without subscribing.
I use my cycleops magnus (or M2 as you called it) with Trainerroad, Zwift, and occasionally, Xert.
I normally powermatch mine to a G3 powertap hub power meter perfectly fine as well.
I have a M2, one classy thing is it gives cadence, power, and speed, not just power (Saris/PowerTap/Cycleops patented a cool power spike = cadence algorithm).
SuperGimp
As for wheel on / wheel off - I believe most wheel-on trainers need to be calibrated every time you use them, whereas I calibrate my kickr about once every other month with no particular issue. Wheel off usually is capable of simulating steeper grades, which may or may not matter to you. No wear and tear on your rear wheel so they're also cleaner to run in your den or wherever.
I personally like zwift because seeing some fake guy go by me on a fake bike motivates me to ride harder than watching a show on TV. Trying to keep up with a fast group, or a race is motivating too. YMMV. I can't STAND indoor trainers for more than 30 min normally but somehow I can tolerate 4 hours on zwift. Go figure. Trainerroad is superior if you just want to do hard core workouts though.
Yes, you can enter the grade, set a power to erg to, etc. and it will record, presenting the information in realtime, as well as giving you the ability to upload it.
