What derailleur cages should I look out for?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1083 Post(s)
Liked 1,818 Times
I'm giving the metal scrap bin a once over before it heads out. It is full of broken bits and I remembered there were others seeking cages for vintage campy.
What are these cages? What do they look like? Don't just shout out a name please, send a pic.
Robert
Robert
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Someone who works at a co-op asked a question like this about hubs in scrap wheels a while ago. What emerged was the fact that no matter how low you set the bar, there is someone on this forum who would consider the part worth saving. I'm not saying you should save everything, necessarily. Just making an observation.
Even broken parts can be useful. I have an old Dia Compe side pull brake that I bought at a co-op because I wanted the beveled washers from the brake pads on it. I've since used four other small pieces from that one caliper to fix other brakes that were missing bits as they came through my garage, Another case, I recently bought a Campy Centaur rear derailleur that had the barrel adjuster broken off. I got the broken bit out with a screw extractor and ended up replacing it with a barrel adjuster from a Shimano derailleur that had the main body broken in half, which I had kept as a souvenir.
So to answer your original question, I would say any Campy derailleur is worth keeping or stripping down to useable parts. The ISO thread on this forum testifies to the fact that there's a constant demand for spares which are becoming less and less available (though someone on this forum always seems to have what's needed).
My Bikes
My Bikes
Quoted: 753 Post(s)
Liked 737 Times
I'll pay twice the scrap rate for any thing Campy......
Liked 1,818 Times
I know. We have a box of broken campy. I don't toss campy.
But, I recall that there was a non-campy (or SOMA) cage that allowed for more teeth and even though it was non-italian, it would work.
I just don't remember who/what.
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 1829 Post(s)
Liked 3,375 Times
This might not be quite in alignment with Rob's request, or maybe it's too obvious... but there is some demand for SunTour Cyclone GT cages.
In my mind, this is for the 1st generation Cyclones, but maybe it applies to the Mark II also.
One reason is that the GT's long cage can be retrofit to the short cage Cyclones, which tend to sell for less on ebay and elsewhere. A complication is that the lower pivot bolt/axle is unique to the GT, so it must be scavenged along with the cage. A second complication is that the nut that retains the axle to the cage is weird and unique, so it's not easy to get off. Honestly, it makes more sense to just sell the whole derailleur for parts and not scavenge the cage and bolt.
Anyway, since the forum is partly just an excuse to post photos, here's a shot of a disassembled Cyclone GT...
The photo also shows a broken spring that provides the pulley cage tension. That's another reason to buy a Cyclone for parts.
I have bought a nice looking short cage Cyclone for the purpose of fitting a GT cage and bolt to it, and it was fairly inexpensive.. maybe $30 or so?
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Likes For Robvolz:
Bikes: Yes
Liked 3,868 Times
Haven't you seen it on here before? Well, I'm always happy to show it again.
Here's a pic when it had that long cage.
It worked OK, but I had a hard time getting past the way it looks -- like something's wrong with my kickstand...oh, that's the derailleur? So, I went back to the short cage and accepted the limited gear range with a smaller big ring and a bigger small ring in front -- 48/42/32.
My Bikes
My Bikes
Likes For Andy_K:
Liked 1,818 Times
The threads been hijacked, but that’s OK, i’m the thread starter.
My favorite part, that the pristine white cotton tape has signs of happy use.
Likes For Robvolz:
Liked 1,818 Times
Ok
ive been looking at campy triples. Even found a 1975.
worried my campy FD doesn’t have enough movement to accept it
Likes For Robvolz:
ambulatory senior
Liked 3,661 Times
