Damn it, Cino!
Damn it, Cino!
I pulled a sweet Cinelli 22.0 stem out of my ancient parts box to put on my Moto Grand Record, then realized that it may well be designed for the old Cinelli 26.4 bars.
Two questions: Its not a good idea to still use a 26.0 bar and crank down on the stem? Sounds dangerous
Has anybody ever fashioned a shim that will work? I mean, pretty tight tolerances here.
Thanks for reading
Thanks for reading
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
I wouldn’t attempt to over-tighten it as you’d run the risk of ruining a perfectly good stem and clavicle and/or jawbone.
I believe aluminium soda can walls are roughly 0.1mm thick (in the US). You might try cutting and rolling up a few turns over the bars...
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
^^^^^^ works for me
Best, Ben
Best, Ben
Voltaire
Voltaire
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
beer can shim is annoying to install but perfectly all good
I just MIGHT be able to round up a beer can. THat was my first idea.
The last question I forgot; What year did Cinelli change from 26.4 to 26.0?
Thanks again!
Thanks again!
Quoted: 3511 Post(s)
Liked 2,926 Times
I’d just try to find a set of correctly sized bars. I hate shortcuts.
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 276 Post(s)
Liked 952 Times
I'm running a shim on two bikes now. Eventually I will swap the bars and/or stems out but one of them has been working well for a couple of years so I'm in no rush.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
I tried it without knowing - wound up breaking the tightening bolt... then I realized what the problem was.
Quoted: 569 Post(s)
Liked 582 Times
Vernier calipers are your friend. Being a beer aficionado I can say be careful, cans were once pretty much all +0.1mm and of late getting as low as 0.08mm so you might want to use a little carbon assembly paste or valve grinding compound mix with your grease.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Likes For cudak888:
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1083 Post(s)
Liked 1,819 Times
I find Cinelli stems prefer Moretti cans or San Peligrino if yours doesn't drink.
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Quoted: 1872 Post(s)
Liked 692 Times
Another vote for shim over here. Worked great on the wife's bike.
2019 Salsa Warbird
2019 Salsa Warbird
Thanks for all the replies/suggestions. Having bikes from the 70s, 80s, 90s and 2K, (not to mention French bikes!) Ive got a hodgepodge of standards. Some can be standardized, some never will. Im not OCD about period correctness, its all about THE RIDE.
The answer may well be to get an appropriate length 22.2 stem and sand it down to fit the 22.0 French headset
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Am I the only one who read the title of this thread and thought, damn, no Cino next year?
Likes For gugie:
Quoted: 1949 Post(s)
Liked 2,010 Times
I’ve read somewhere that Cinelli tolerances were pretty tolerant. If the bars are loose, shim. If they are not, clamp ‘‘em down.
Quoted: 554 Post(s)
Liked 3,794 Times
Liked 2,926 Times
