Vintage Gravel Grinders
#127
Quoted: 5888 Post(s)
Liked 3,471 Times
70s Motobecane Grand Record
This is likely a '73 Motobecane Grand Record. It has a lot of clearance. I'm running 700 x 35c Schwalbe Marathon Mondiale tires. The gearing is good as well: 50/34 up front and a 14-28 five speed in the back. Thanks to nlerner for the Nervar 631/633 crank with the 50/34 rings. I
I took it for a shake down cruise today which includes some gravel roads. I like how this bike rides over gravel.
The paint on the bike is crackled which happens to some of the early 70s Motobecanes. It's perfect for a gravel grinder:
Likes For bikemig:
#128
Question for you all that like to use vintage C&V for your gravel rides: I'm wondering if you feel like you should size down on the frame if you may be doing a bit more technical riding on your rig? Or do you stick with your road size and go for it? My background is in mountain biking and my MTB bikes have all been smaller frames than my road bike.
#129
Bikes: 1997 Trek 2300 & 1991 GT Tachyon
Quoted: 9 Post(s)
#130
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
I have to come off my gravel bike mid-rid as frequently as I come off my road bike, which is about never. I guess if you are needing to emergency dismount frequently, a lower top tube height may help?...but maybe a different bike would be best for whatever type of riding you are doing at that point.
ETA- I ride 63-65cm road bikes and my current gravel bike is a 58...but thats because it has a sloping top tube. The stack and reach of my gravel frame is actually almost exactly the same as my main road frame.
#131
Quoted: 9 Post(s)
I wouldnt downsize if that results in a significantly different fit, like a much shorter top tube. Gravel riding is just road riding on unpaved roads. If a road bike fits- replicate it.
#132
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
Does this count? 1989 Specialized Rock Combo. Since the picture, I've replaced the tires with Schwalbe Land Cruisers for more traction on the loose stuff.
