Light mount for side of fork
Quoted: 2975 Post(s)
Liked 1,182 Times
@prj71, perhaps you need to look at a shaped beam to see what it's like. If it's sideways or upside down, it's extremely ineffective. And I'm not asking how I can eliminate the mount I already have and works well. I'm asking if such a thing is commercially available because it works so well for what I need. So I think you're underthinking it, i.e. offering a solution to a problem different than the one I have. If I ask you what the weather is and you tell me what time it is, it doesn't matter how precise your time readout is.
Quoted: 7348 Post(s)
Liked 2,471 Times
@prj71, thank you.
Quoted: 3461 Post(s)
Liked 1,466 Times
Plan B.
Your photos do not show if you have much room above the tire or not, like a handlebar bag. Note the front light I have on my road bike, below. If you have much room above the tire, you could put your light above the wheel.
I used this light mount, it is an off-the-shelf B&M light bracket:
https://www.bikeinn.com/bike/busch-m...nt/137506734/p
If you had the tools to bend some stiff metal like that bracket, perhaps you could make it a bit wider, and cut a 3/4 or 1 inch long piece of round wood dowel or broomstick handle to mount inside that bracket?
When I ordered that B&M light mount, I had no idea if it would work with my sidepull brakes, but it works without any problem, the light does not impair brake operation at all. I can't say that would be true with your brake too or not, but the bracket is a low cost so it is not a expensive risk to try it. I think Peter White sells that bracket, but I bought mine from Europe.
Quoted: 1829 Post(s)
Liked 3,376 Times
FWIW, here's something I did about 13 years ago, when I needed to mount a light to the fork blade of a recumbent.
It's pretty basic... just a "T" shaped bit of steel and two hose clamps. These were standard stock items at the local Ace hardware store.
Well, I did put a layer of old inner tube around the fork blade before clamping the T-shaped bracket with the hose clamps, but that's about as complicated as it gets.
Not the prettiest thing around, but functional.
Steve in Peoria
Steve in Peoria
