Looking for N=1 -- 85% pavement. And no Grails to be found...
#51
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Ha, well then you would lose your mind on my gravel bike that has 72.5deg HTA and 60mm of trail. Gravel roads are just roads- an endurance road bike with room for a wider tire is all I need.
#52
Quoted: 2976 Post(s)
Liked 1,182 Times
But not all gravel roads are the same. Some of my grave routes are marble size stone that often feels like you are riding on real marbles. The steeper the HTA the twitchier the steering is going to be. A little slacker HTA works better for these types of roads.
#53
Sunshine
Liked 7,491 Times
Agreed, not all roads are the same. I was just observing how you for sure would dislike what I ride. Nothing more nothing less.
Likes For mstateglfr:
#54
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
And mstateglfr, I agree with your post. You can ride anything almost anywhere. I take my gravel bike on most MTB trails around me and do fine.
#55
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
My Stigmata has a 72 deg HTA and it's perfect from 100% full on road rides to semi-technical single track. I wouldn't want a bike much slacker up front for versatility like that.
Likes For KJ43:
#59
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
Nice to see the conversation continued a bit -- I didn't sub to the replies so apologies.
Update:
I checked out the Aspero and Caledonia in person last weekend. The Caledonia is, at the end of the day, a road (only) bike. It's off the list (it was barely on it, but I wanted to consider it). In chatting with the shop (Ben, nice guy at pedal in Littleton), he also pointed towards the C'dale Super6 EVO (they're also a C'dale shop, so grain of salt noted). I'm trying to stay away from Spesh/C'dale/Giant/Trek --not because I'm anti-big companies, but I've owned them in the past and want to go elsewhere. In fact, I sold my Crux just last Nov -- I woulda kept it 'cept it was cantis and I want to jump into discs and less of a cx-specialist geometry. Spesh makes great bikes, but also seem about $1-2k higher for similar component spec against other brands. I've also owned a Trek road bike (2003 2300 w Ultegra). Also good bikes. Just like the smaller guys and having something a little unique on the road. Shrug.
The Aspero is still a contender, and the same shop has one in my size (58) with GRX600 (my budget) coming in April. Has me really thinking about it. The Look 765 Gravel keeps coming around too, and there's one out there. Three bottles inside the main triangle? Yesplease!
The Warbird keeps coming up. Why did I say it's "too gravely?" -- 70.75* HTA, 430mm chainstays and a 1070mm wheelbase. Coming from a 999mm wheelbase, I don't want to feel like I'm going from a rocket to a recliner. Yes I know it's numbers-staring, and Yes I know things are different out on the road. There's also the availability issue.
So. Where does that leave us? Well, ever the "let's keep interneting because I have to pay taxes first," I saw an Obed Boundary on CL and went to check out the brand. Guess what? The Obed (sister company with Litespeed and Quintana Roo) has the GVR. The GVR is just what I'm looking for. And they're more or less available (4-week build). And they're pretty configurable. And a GRX810 build is under 4k, which has the 48/11 instead of the46/11 on the GRX600. And I can add mounts. And I can spec the right tire. And it has colors!
Ladies and Gents, I think this is my jam. Just need to get taxes paid first: https://obedbikes.com/products/gvr-g...41210312458415
It's fun to play with the color schemes...
Update:
Likes For superdex:
#60
Quoted: 394 Post(s)
Liked 197 Times
Update. Pulled the trigger on the Obed. In a last-second concession, I chose to go without the rear fender/rack brace, since the fork on the GVR don't have no eyelets anyhow. I slept on it and called them up and added the seatstay bridge and the toptube mounts. Just in case, y'know. So I'll go with SKS Speedrockers when the time comes. 5-6 weeks from now, I'll have my N=1...
Likes For superdex:
#61
Quoted: 394 Post(s)
Liked 197 Times
I got an email today
5-6 weeks is looking like it's spot on. Tick tock tick tock!
Likes For superdex:
#62
Quoted: 426 Post(s)
Liked 274 Times
I am going through this myself. I want an s-works cruz but lotto and stock market have been failing me.
I want 2x grx with thread bottom bracket, kind of lite. ( very lite s-works crux is over 10k )
I think that only really leaves the Stigmata around 5k. If you don't mind a little more weight and a lot of savings in your pocket you can buy alloy top stone 2x with threaded bottom bracket for around $2,300 ish
topstone 1
topstone 1
#63
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
topstone 1
topstone 1
Having done a few gravel races myself...I think these gravel bikes with ~71 degree HTA are too steep. I think Fezzari nailed the correct HTA at 68.9…..
… Some of my grave routes are marble size stone that often feels like you are riding on real marbles. The steeper the HTA the twitchier the steering is going to be. A little slacker HTA works better for these types of roads.
I find with a steep head tube angle, I can really dive into a turn hard, and curve a tight arc – which is great for pavement, not for gravel.
Twitchiness – that seems to be mostly due to stiff arms and upper body, not the bike, no? I can ride any bike I’ve owned with no hands (removing the stiff body factor), so I’m blaming twitchiness on myself.
In the end, Trail and wheelbase are more important than HTA, with wheelbase being the main factor. I can drift my OG mountain bike (with steep HTA and long wheelbase) all day long, but I can’t for the life of me drift my fast short wheelbase gravel steed.
Likes For chas58:
#64
Liked 1,182 Times
When a bike has a slacker head tube angle the steering is slower at low speeds, but the extra stability associated with relatively slower steering will moderate the behavior of the bike at higher speeds.
Likes For prj71:
#65
Quoted: 394 Post(s)
Liked 197 Times
So ... here she is. Got a 13mi mixed surface ride in tonight as soon as I could throw pedals on and adjust the saddle. I'm in LOVE!
Likes For superdex:
#66
Quoted: 394 Post(s)
Liked 197 Times
Okay, so it was late and I didn't spend the time to review the GVR, so here's a few random thoughts from the initial ride yesterday:
* Over all impression? It's gorgeous. I love the matte finish and I can't complain about the color scheme (because, you know, I picked it). I had a small fear just as the truck pulled up that the steerer would be cut too short. In the pic above, it looks like a ton of handlebar drop because the seatpost came just so high. Thankfully, with the saddle in its right spot, the handlebar drop is just about perfect. Phew!
* Haven't been on Shimano 'road' group in years. Shifting was precise but mechanical. I do love the way Campy slides into gear. The FD needs a small click trim from the bottom half to the top half of the cassette. That's really tight. Will have to just get used to that. Is it just me, or does the grx crankset look kinda low-end aesthetically? It reminds me of the Acera crankset
* 38mm Tires are sweetness, and the gravelking SS is just what I want. I didn't feel like I was giving up too much on pavement, and had plenty of traction on the dirt
* Somewhere between geometry and tire width/pressure, I felt I could go through dirt corners multiple mph faster than previously, including my hardtail mtb with 29x2.6 tires. Front tire always felt planted and secure, even through patches of looser stuff.
* The bike jumps under power (a good thing). It's my first carbon bike and while I could notice a little more stiffness from my steel Goodship, it's not a bad thing. The Fizik Vento Argo R3 saddle, on the other hand, is really stiff. Maybe it needs to break in a little.
* One write-up (on slowtwitch I think) espoused the bike's bombproof-inspiring handling on unpaved surfaces. I'd agree. It's not twitchy and it's not pokey. It just felt dialed. Is it my quiver-killer? That remains to be seen -- I do need to dial in the fit a little more, but it has every potential to be the grab-and-go-no-matter-the-day bike I was looking for.
(now I just have to wait until Monday to ride again with Life taking over for the next few days. Argh!)
Likes For superdex:
#70
The steeper the head angle and the bike becomes twitchy...Meaning the bike reacts faster to steering input making it prone to over steer, which IMO is a bad thing on gravel and even worse on downhill gravel when riding at higher speeds. Oversteer with a front tire riding on marbles (gravel) is more often than not what causes a crash.
Dude, I love it. It looks way better in person than on the website. Those stickers on the rims have got to go though.
Did you get a final weight?
Likes For Phatman:
#71
Quoted: 394 Post(s)
Liked 197 Times
Oh hey, I finally broke out the scale -- with cages and pedals (Candy 1), it's 21 1/4 lbs. I can't find weights of the Sun Charger Comp wheels, but I imagine the bike will lose a pound or so when I swap those out, eventually. On dirt, it feels faster than my Timberjack which is expected, and on the road not quite as sprightly as my Goodship (with 45mm deep carbons, 15mm shorter wheelbase, and weighing just under 20lbs), also expected. It hits the sweet spot, I'm a happy camper
#72
Sunshine
Liked 7,491 Times
...or are the wheels really good, but you are going to buy some exceptional ones? 450g or more to drop off a wheelset led me to think the stock wheelset is very basic and heavy.
It is a really nice looking bike, to be clear.
#73
Quoted: 394 Post(s)
Liked 197 Times
So this will come off poorly, but is really meant to be surprising. A $4000 bike has heavy basic wheels? That seems frustrating.
Seems the market (inflation notwithstanding) for a carbon frame+GRX 810+decent kit is around that $4k mark (plus or minus) -- the Aspero GRX is specced with Easton EA70 AX, also a $250 wheelset and is $4k. Shrug. (Yes, I'm knowingly hand-waving over the whole Obed<->Cervelo brand cachet comparisons; I just like to pick on Cervelo)
So, I guess they are "decent" wheels; tubeless ready and all, but I'm only guessing that's where some extra weight is because the reviews of the bike online are all with the carbon option (HED Emporia, +$1600) and they talk about the bike being sub-20. There are a few wheelset options on the site and I chose the cheapest on purpose as I do plan on some LightBicycle carbon hoops come Christmastime as a 2nd, more road/aero option (and I was maxxing my budget as-it-was)
