Noise on each pedal stroke?
On my TARDIScycle!
Bikes: Trek 520, Trek Navigator 300, Peugeot Versailles PE10DE
Quoted: 5 Post(s)
That's what I'm hearing...a noise on each pedal stroke. Kinda of a clunk, but not too loud.
I've verified crank arms are tight. Nothing seems to be hitting. I can't reproduced it unless I'm riding the bike...it doesn't seem to happen that I can tell if I put bike on rack and spin pedals.
Any ideas?
Any ideas?
Does it only happen under pressure? What I mean is, if you are sitting on the bike, but peadling without much force) does it still clunk? Also, does it happen once per pedal rotation? I remember reading a Sheldon Brown article on how many noises that only happen when we're on the bike can be something unrelated to the mechanics of the bike... For example, are you sure a part of your shoe isn't rubbing on the frame or crank arm somewhere? Are you sure your leg isn't hitting the tool pouch under your seat? I know these all seem like obvious things, but sometimes it's just that simple...
On my TARDIScycle!
Quoted: 5 Post(s)
I'm pretty sure I'm not hitting anything with my shoe/leg. I can almost feel it when it happens (yes, every pedal stroke). It kinda "feels" like there's play in the crank arm, but I can't detect any play....that's just the kind of "feel" it has.
Bikes: Waterford 1900 Adventure Cycle, Gunnar Sport, Cannondale T700, Giant Yukon
Check your seat/seatpost for bolt tightness. I can't believe how often I track down noises to the seat.
On my TARDIScycle!
Quoted: 5 Post(s)
Broom Wagon Fodder
Bikes: Fuji Supreme; Kona Wo; Nashbar road frame custom build; Schwinn Varsity; Nishiki International; Schwinn Premis, Falcon Merckx, American Flyer muscle bike, Motobecane Mulekick
Quoted: 52 Post(s)
Liked 64 Times
I just had the same problem. It sounded like the seat was squeaking. I checked that. I replaced the chain-ring bolts after one broke while I was seeing if they were tight -- later discovering that they should only get about 7 ft-lbs
After none of that worked I swapped pedals and the sound is gone.
Bikes: 2006 LeMond Croix de Fer, 2005 Kona Dew Deluxe
that happened to my eggbeater pedals when they needed rebuilding. It was most obvious when standing during hill climbs
I just dealt with a similar problem myself - turned out the pedals weren't torqued sufficiently into the crank arms. When I put a wrench to them the sound disappeared. Almost missed this very easy fix because when I checked the pedals by hand there was no play.
