Fenders being knocked skew?
I'm obsessive compulsive and I adjust my fenders every time they get knocked off centre.
Is anyone else irritated by this?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
hmm, my fenders usually never go out of alignment when I bend the arms properly.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Jeff Foxworthy variety
Bikes: Eight of them...
I'm the same way... it drives me nuts when something's not centered on the bike, to the point that I built my own fender stays out of 1/8" thick aluminum flat stock, partially to keep them centered, partially to keep them from buzzing the tires.
Liked 5 Times
pair of pliers and a monkey wrench. works better than just hands since you want it straight at the ends.
Bikes: Many all steel.
are your eyelets properly aligned and or parallel? could be part of the problem, that is assuming you have eyelets. I rarely have a problem myself barring a collision 'knock wood'.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
What kind of fenders?
I run SKS P-45s on my commuter, and they haven't been off center since I set them up. (Although, I do need to make some spacers and hanger extenders to get a better fender-line against the wheels.)
Randomhead
Liked 3,698 Times
When I was a mechanic, I used to adjust the fenders of the bikes I worked on if they were out of whack. Can't take that sorta thing.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
The mudguards on my Frankenbike were bought for the Europa in the 80's. Somewhere very early on, the front guard developed a twist just in front of the fork which I've never been able to get rid of. The bike looks as though it's had one too many at the pub before heading for home.
Richard
Richard
Wear a helmet
Bikes: 1975 Dawes Super Galaxy 531 tubes, 1998 Condor Squadra
Also (as a reply to the OP i do get annoyed when they're not centre!), is it me or are the non-permanent mug guards a nightmare to get set up properly so they don't rub or should i just get some full mudguards like my tourer does?
Sam
Sam
Wear a helmet
One more thing, i've found you can bend those plasticy mudguard back to shape roughly with careful use of a hairdryer. You can make the plastic soft enough to adjust. Just don't do it too much and try to get it good first time otherwise you start weakening the material.
I'm not a bit irritated by your constant adjustment of your fenders, in fact I wouldn't have noticed at all if you hadn't brought it to my attention.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I don't bother with them unless they're rubbing. They're usually covered with so much mud that getting worried that they're 1/4" to the left or something is kind of silly. The only time they go out is if I lay the bike on something with a wheel off and it really pushes the fender to one side.
I have SKS fenders; I can grab one of the stays and give it a sharp twist just with my hands to recenter things. They have the stiffest stays of any I've used (I've had Freddy Fenders and some other brand also).
Work: the 8 hours that separates bike rides.
Light Makes Right
Bikes: Gianni Motta Criterium, Dean Hardtail
Yeah, I have the SKS fenders and do a bike-and-train combo ride. The way the train is setup, the only way to attach it so I can sit down rather than standing with the bike is to use a toe-clip strap to lash the rear wheel firmly to the handrail. In doing so I push the fender all the way over so that the stay is against the tire. I do this twice a day, 5 days a week. Every few weeks I notice the fender is a mm or two off center in the direction it always gets pushed. A slight nudge centers it right back up. Good stuff, SKS.
Bikes: Felt F4; Surly Crosscheck
I'm the same way with my SKS fenders. If I lean my bike against a wall it will sometimes knock my back fender slightly off center, and if I notice it I will always twist and tweak it until it is just so.
I'm hyper-compulsive about everything on my bike, not just the fenders, but I now am at peace with the fact that something will always be a little bit off with my bike, no matter what. Reaching this point of acceptance is important, or you may someday find yourself at 2AM trying to get the bar tape on your bike perfectly symmetrical, asking yourself how everything went so wrong.
I use Planet Bike Cascadia fenders. They were perfect when I first threw them on my new bike, but on one of my first rides, the articulated knee panel on my Showers Pass rain pants got caught on one of the fender stays, and since it was a fixed gear bike, my knee kept moving forward and pushed the fender skew. This bent the fork mounting plate to one side slightly and now the fender is a pain to adjust.
Oh well.
Oh well.
