GMC Denali Road Bike : Broken Spoke's
Bikes: 2009 GMC DENALI (walmart bike)
Well I should have learned my lesson, but I checked my bike about a month ago and one of the spokes on the wheel came off and the spoke just layed at the side of the other spokes not doing anything. I should have stopped riding the bike then, come 100 miles later and today when I went out for a late night spin about 5 spokes came loose and one of the spokes went into my chain at the back wheel and it stuck the chain while I was trying to shift about 10 yards from my house. The chain came off the cogs and the bike and I was riding with no chain and came to a stop. Close to my house so I just took the bike to my house. And saw that 1 of the cheap rather plastic-like maybe alloy spoke was stuck in the chain.
So what should I do? can I repair the spokes? I dont want to put any money on this crap bike, but I want to ride it out this winter, come spring I will have a killer new bike. So I dont want a new wheel, IDK much about bike wheels but what do the spokes do? can I just throw away the spoke pieces that came loose? This bike is made to break I swear.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
You could get the wheels rebuilt but it won't be worth the effort. Just get some new wheels, they don't have to be spectacular.
Spend like $240 on a cheap heavy set of mavic open pro/ultegra wheels from a reputable builder (psimet, bicyclewheelwarehouse.com). Then you can use them as training wheels on your new ride also.
Bikes: 1989 Team Miyata, 1989 Miyata 1400, 1989 Miyata 1400, 1986 Miyata 610, 2007 Specialized Stumpjumper Hardtail
Quoted: 16 Post(s)
I'd pick up a set of these https://bicyclewheelwarehouse.com/ind...d&productId=49.
Bikes: A little of everything
Quoted: 7 Post(s)
Take the tube and tire off the rim. Note the size of the rim (either 622/700cm- they're synonymous; or 27"). Take a pair of tin snips and cut all of the spokes; trash them. Keep the hub (with the skewer or bolts) and cassette (gear cluster). Take the gear cluster assembly and tube/tire to a shop and ask for a new wheel- they'll be able to identify exactly what you need with those parts and info, and salvage the gear cluster off the old hub that you saved.
Before you go buying wheels such as those mentioned above you need to know what you have. Does the Denali even use a cassette type rear gears or does it use a freewheel? You need to make sure that what ever wheel you purchase will accommodate your gear system. You may end up being better off having a custom wheel built around your existing hub.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
meh, you guys dont understand this is a 99 buck bike it isn't worth buying a new wheel, sheesh the new wheel would cost more than the sticken bike, hahaha. I am just going to use my old 15 year old mtn bike for the winter a buy a new bike in the spring.
We understand.....We are just telling you your options....
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Yes, but the wheels I recommended along with the other mavics which were recommended would be great to use on your new bike also. Think of them as an investment.
How long have you had the bike? Return it to Target or Walmart or wherever you bought it, get a new one, and have the wheel properly tensioned before you ride it. Even a Denali wheel should hold up just fine if adjusted before its ridden. If people return their busted **** more often, maybe (x)mart would be less inclined to sell such poorly assembled bikes.
I doubt a wheel that would work on a modern day LBS type bike would even be compatible with his Denali
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Quoted: 7 Post(s)
Edit: but if that doesn't work, and you still want a road bike, seriously consider my advice. Talk to the people at your local shop- I bet a new wheel is less than $60 (plus maybe some labor to swap the cassette), and you'll save money by salvaging the parts I told you to keep. The people above suggesting $240 wheelsets aren't thinking straight.
And yes, the Denali is a freewheel, screw this bike, it was my first road bike, in that I could get up to 20 mph on the flats but that's it, my first true road bike will be bought in the spring, but I have to thank the Denali for getting me back into riding the bike and enjoying myself and getting me in shape. I also have a indoor recumbent bike which I can train on and exercise on until spring, so I will be fine, but nothing beats going out in the elements and riding the tarmac.
Hey you're the one who came here asking for advice...
If it were I; I'd keep that bike. Upgrade as things break, like the wheels for instance. Slowly but surely replace everything but the frame. I've seen one or two of those bikes on here that guys fixed up pretty respectably for not a lot of money. Then keep it as a rain/bad weather bike.
This way, when you get the nice bike you don't have to dirty it up during inclement weather or training rides.
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
If you don't want to buy one of the recommended wheels (keeping in mind that they will be good for future use of course), you can take your bike to bike club at falls church (https://www.bikeclubva.com/). I've heard nothing but great things about them, and visited the store a couple of times. I'm sure they will be able to salvage the wheels and get you riding it till spring. It is a small shop and they have fair priced second hand bikes as well.
True but it did do its job. You got a bunch of miles out of it and now you know that it is worth your time and money to upgrade to a better bike so you shouldn't really have any regrets
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Quoted: 16 Post(s)
Yep, thanks guys for all your input, I have decided to just trash the bike, its 57cm and I am 5'8", rofl, you must be wondering how I road the bike for that long, it was way to big for me, but I adjust around it. But on long rides, even my back (which is rather strong) would ache. I am just going to get rid of the bike and wait for spring for a new bike. In the mean time I am going to buy books which people referred to me here on the forums, and learn about bike mechanics.
Come winter I'm going to save some colds and fevers and just stay inside and ride my indoor recumbent bike. I also have a mtn. bike I can ride when I really have the urge to ride.
see ya on the road come spring, but see ya on the forums all winter still.
As other posts have pointed out though, it sounds like you wouldn't be able to use a new wheel so it's a moot point.
