replacement quill stem top caps
Old 06-28-22, 09:02 AM
theblackbullet
theblackbullet's Avatar
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times in 77 Posts
I have a Tioga Prestige stem that I'm very attached to. The stem has unfortunately been overtightened in the past, and the top cap (aluminum) has cracked. Browsing through ebay, it seems like the road version is hard to come by. This particular stem is 22.2 (1" steerer) with 25.4 clamp, 130mm long, and no rise. I started to look into having a replacement turned on a lathe, but cost adds up quickly to where it doesn't really make sense. Then I stumbled upon this:
https://analogcycles.com/products/di...40096144949425
It looks like it should be a perfect match!
Original:
For some reason however, they won't ship to my address. I'm reaching out to them to see if there is a solution, but in the mean time, I figured it would be worth asking to see if anyone else knows of another alternative. I really like these chromoly stems, and would like to keep this one in use!
theblackbullet is offline
Old 06-28-22, 09:33 AM
smd4
Quoted: 3511 Post(s)
Liked 2,926 Times in 1,775 Posts
Not sure why they won't ship to your address. Can they ship to your place of work or a friend's address?
smd4 is offline
Old 06-28-22, 09:57 AM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
Simworks makes a stem like that. Maybe they'll sell you a cap?
icemilkcoffee is offline
Old 06-28-22, 11:14 AM
mtbikerjohn
mtbikerjohn's Avatar
Bikes: a few..
Quoted: 82 Post(s)
Liked 147 Times in 95 Posts
I was just about to recommend Simworks,too...Their's is made to fit a Nitto,tho
mtbikerjohn is offline
Old 06-28-22, 11:15 AM
mtbikerjohn
Bikes: a few..
Quoted: 82 Post(s)
They are available separately..
Old 06-28-22, 11:24 AM
zandoval
zandoval's Avatar
Quoted: 966 Post(s)
Liked 1,629 Times in 1,045 Posts
Can you repair the crack?
zandoval is offline
Old 06-28-22, 11:42 AM
theblackbullet
Bikes: I don't even
Quoted: 81 Post(s)
It seems it was an issue with the website. It is calculating shipping totals now. Oops!
Thanks for the lead! I think that one would work too! Out of stock at the moment, but noting for future use!
I don't imagine there is too much different between the Nitto and the Tioga as they're both chromoly with a 22.2 OD
It's a catastrophic failure. I'll post a picture when I get home.
Likes For theblackbullet:
Old 06-30-22, 04:08 PM
theblackbullet
Bikes: I don't even
Quoted: 81 Post(s)
For those interested
Old 06-30-22, 04:45 PM
smd4
smd4 is offline
Old 06-30-22, 07:46 PM
madpogue
Quoted: 2363 Post(s)
Liked 1,749 Times in 1,191 Posts
That won't buff out.
madpogue is offline
Old 06-30-22, 08:54 PM
jdawginsc
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times in 1,967 Posts
Industrial strength superglue?
jdawginsc is online now
Old 07-01-22, 01:21 PM
stardognine
Partially Sane.
stardognine's Avatar
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times in 468 Posts
Thanks, you made me snort potato chips up my nose, backwards. 🙃😉
I also noticed, the OP must be a pretty big dude, to do that to the poor innocent stem. 🤔
stardognine is offline
Old 07-01-22, 01:43 PM
madpogue
Oh, I should post a pic one day of what some, er, large-ish gentleman did to a perfectly good and quite nice Concept One stem on a Univega Alpina Comp I bought at the thrift store, that someone had turned into a geezer-glider. I almost cried when I pulled it.
madpogue is offline
Old 07-14-22, 02:57 PM
theblackbullet
Bikes: I don't even
Quoted: 81 Post(s)
It cannot be proved that it was my fault! May have been the previous owner! I never looked until I put it on a new bike! haha
Regardless, to bring this post full circle in case someone down the line with the same stem wants to replace or bling it up a little bit, I ended up buying the SimWorks top cap because it was a little cheaper shipped. It works, but I had to use a Nitto stem bolt that was in the parts bin. No issues otherwise!
Note: I am NOT the person who did that to the headset top nut!
Old 07-14-22, 04:48 PM
smd4
Looks sharp!
smd4 is offline
Old 07-14-22, 05:06 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
It's just a stem cap. In a pinch you could make one from two pieces, a piece of al roundbar that fits inside the quill and al plate cut with a hole saw. Drill the centers of both for the bolt. Slide each on and wrap tape around the bolt to keep the roundbar from falling.
Crude, yes. But all it has to do is anchor the bolt head so you can get your stem bolt moderately tight. 90% of its function is the appeal. (What you got looks a lot nicer.)
79pmooney is offline
Old 07-14-22, 06:03 PM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 974 Post(s)
Liked 512 Times in 352 Posts
looks like corrosion? from dripping sweat over the years? Did the previous owner ride it on a trainer indoors?
Isn't all the bolt's force on the top ring part? The bottom sleeve is just to hold it in place correctly? If so, that's really odd that it fell apart there.
I like the red one, looks good!
rm -rf is offline
Old 07-15-22, 04:13 AM
theblackbullet
Bikes: I don't even
Quoted: 81 Post(s)
Looks sharp!
thanks!
I had initially considered purchasing some bar to take to a lathe and have it turned down. The cost of the bar made it cost prohibitive. ~$30 for a 12" segment. Really happy this one worked instead.
Yes lots of corrosion in there. Enough in the crack to make me think it had been there for a while. It came from a Diamondback Expert TG frameset that is actually surprisingly clean so I don't know the history. It is an odd failure!
Old 07-15-22, 06:27 AM
smd4
Seriously? In a "pinch," He could maybe try to smelt the aluminum himself.
Why do you guys always have to explain the most difficult solution to a problem that's just a few phone clicks away, with the most tools possible? It's not the apocalypse...yet.
smd4 is offline
Likes For smd4:
