Rivendell Atlantis or Vintage
#76
So to address the topic of the original post...I think that you could try out something vintage relatively inexpensively and decide if that is for you. For example, here's a Bridgestone RB-1 for $300. CLASSIC BRIDGESTONE ROAD BIKE
If you try something vintage and it doesn't work out for you, then just reevaluate what you would like to be different and go from there.
Marc
#77
Quoted: 68 Post(s)
Liked 84 Times
"A 55cm Roadeo frame weighs just under four pounds. The lightest MCRB frames weigh about two pounds."
"It's not far off the mark to say we don't care about weight"
"They weigh roughly 4.5 lbs and 1.6lbs respectively, compared to maybe 3lbs and 1lb for a same-priced carbon combination."
I'm sure I could find more if I put another 5 minutes into it.
#78
Quoted: 68 Post(s)
Liked 84 Times
Yeah, they're almost identical. Except Jobs was a forward looking innovator, dreaming of a future with unlimited possibilities. And Grant is a backwards looking retrogrouch, dreaming of some imaginary idyllic past.
#79
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
#80
Bikes: 1966 Carlton, 197X MKM, 1983 Trek 620, 1988 Schwinn High Sierra, 1995 DBR Axis Ti, 1999 Waterford, 2016 DBR Release, 2017 Surly Travelers Check
Quoted: 65 Post(s)
Liked 7 Times
Sigh...From Grant's blathering website.
The burden of proof is one one making the claim. I too can find off-hand remarks about weight from manufacturers about bikes not under consideration here.
#81
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Colnago Classic Rabobank Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3101 Post(s)
Liked 6,642 Times
Guys,
Can you stop with the back and forth bickering?
Quoted: 5891 Post(s)
Liked 3,475 Times
Beauty is in the eye of the beholder. I would think that "porky" should be a badge of honor for Riv'dell bikes since they are intentionally overbuilt; not a bad thing in a bike you want to last a life time.
#83
Quoted: 65 Post(s)
Liked 7 Times
Finally, some reasonable advice. It's tough to compare a Riv to a vintage anything without riding them both. The most practical option would be to find a vintage bike suitable for touring, upgrade whatever components you think are practical and if it works for you fine. If not you can take the chance on a Riv frame later. That's the cheapest way through the maze.
Marc
Marc
My other 2cents: I got to trade a guy my High Sierra for his Riv Atlantis for a day on tour. We covered 60 miles of pavement, gravel and packed dirt. The Riv was exceptional (cockpit preferences aside.) At the end of the day we were both smiling. He had more fun on some light single-track/country roads, I had more fun on long stretches of gravel.
One big plus to the modern Rivs is that they have most of the great things about high-end vintage bikes, but they lack most of their oddities. They have normal spacings and specs everywhere. No weird 1 1/4" headsets, no ankle-biting U-brakes, no M6 lowrider braze-ons. Dialed geometries, tons of braze-ons, great paint, beautiful craftsmanship.
If you're value hunting Rivs aren't worth your time. A $50 High Sierra is a better value. But if you're after a beautiful lifelong companion where money is no object and you don't want custom made Rivs are a great choice.
#84
Just Plain Slow
Bikes: Lynskey R230
Quoted: 297 Post(s)
Liked 5 Times
While the Atlantis is a classic in it's own right it ain't cheap. Seems that there are plenty of 80's vintage MTBs that could fill the bill nicely. Has anyone here tried it? I have an 84 Stumpjumper that seems like a perfect candidate. The drop bar MTB thread has plenty of great looking bikes on it for inspiration. What say the experts?
The ankle-biting bickering has to stop. And personal insults will not be tolerated. Posts that have contributed to this have been deleted.
Thanks.
#85
Bikes: 1978 Raleigh Competition-1974 Raleigh Folder-1983 Austro Daimler-198? Fuji Monterey-Surly LHT-Surly Karate Monkey-Surly Cross Check
Quoted: 43 Post(s)
Liked 97 Times
Hurray!
Just a reminder of the original question. This thread has gone so far off-topic that I thought it would be a good reminder.
Thanks.
Thanks.
#86
Thanks.
Thanks.
#87
Vintage hybrids are another alternative, I'm building this old miyata triple cross into a rainy day rando-style bike. It's got standard braze-ones for light touring as well so it might end up getting used for overnight trips. There were a lot of nice hybrid bikes made in the late 80s and early 90s that might have comparable geometry to a rivendell and they tend to get sold pretty cheap since they have flat bars... they usually come with triples and long-cage derailleurs so if one is lucky all it needs are bars, levers and shifters to get it into rivendell-esque condition. I do like converting MTBs to drop bars for my shorter friends though, but sometimes the top tubes on the MTBs are a bit long.
#88
Liked 3,475 Times
#89
I'm doing it wrong.
Liked 2,812 Times
It's a legitimate question. I don't think an old mtb will give you the same ride as an atlantis (geometries won't be the same) and it won't look the same, but you could certainly set up one like you would an atlantis and do everything you want on it and it should ride fine. It is certainly a great alternative than plunking down the change for a Riv.
#90
Extraordinary Magnitude
Quoted: 2609 Post(s)
Liked 1,704 Times
My father in law has an early 90s Criss Cross. It's pink and purple. Maybe that has something to do with the "respect?"
Commence to jigglin’ huh?!?!
#91
#92
I'm saddened by the fact that the lowend steel/cro-moly market has completely evaporated.
The $300-400 steel bike segment used to dominate 25 years ago, with models like the hardrock such and such flooding college campuses. Those were darn good commuters and just plain fun.
Is it really that difficult to produce a $300 cromoly bike that can move a few units on the showroom floor?
I suppose alu is cheaper and lighter, but dear god those steel bikes were such great values.
We shouldn't be forced to shell out $1300 for a lht to get a decent steel bike.
I doubt GP cares, but I'd love to see rivendell produce a line of affordable, sub $1K bikes with some cost cutting compromises that don't compromise function such as tig welded frames.
#93
Liked 3,475 Times
I like a lot of things about GP and about his bikes but at the end of the day, it's just a bike. There are plenty of other good bikes out there.
#95
one life on two wheels
Liked 18 Times
Get both a Riv and a vintage. Ride them around. If you don't like one or the other, sell it. If you like both, keep 'em.
#96
If I was to choose one bike from the stable, that would be the one. I hear the same thing from people who own a Big Dummy.
I love my Hunq.
Marc
#97
Bikes: Yes
Quoted: 301 Post(s)
Liked 15 Times
If it were me...
For the 2400 bones on the Atlantis I would much rather get a custom build. Most builders will size you, allow your choice of tubeset, and other than a long wait the end result is almost guaranteed to be better than an off the peg frame. Maybe you'd spend $300 more, but you get just exactly what you want. Only downside is you need to know just exactly what you want.
If I were after an off the peg frame with the same general "vibe" that rivendell sells based on, I'd get a Bob Jackson, which has a long running history and they use 631 tubing which is probably as good or better than the tubing in the Atlantis.
However, in this realm of heavier bikes, I'd be much more tempted to find a nice 80's tourer and take that in whatever direction you want to go with it.
So on the whole, no issues with the Atlantis other than the high price.
#98
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
#99
Bikes: 89 'stone MB-1, Kona Kaboom SS, Univega Activa Country Hybrid, Peugot 80's POS 'US Express', 90's something Bianchi Ibex, 80's someting Diamondback Viper BMX, 70's something free-spirit townie/cruiser
I think there is a missing leg to the controversy surrounding Rivs: the finished product. Sure, you can find geometry that matches pretty closely to a Riv. But thats true for every single manufacturer EVER. Bikes are relatively identical, with the exceptions of Moulton's or big wheels, but the 'safety bike' is ubiquitous in design: a series of triangles which make a rough diamond shape. But with Riv you get a nicely lugged (and by that I mean have you looked at how nice those lugs are!), beautifully painted, thoughtfully designed bike. Designed by one of the most influential designers in the industry (thats irrefutable).
Go ahead and compare your surly, or your old repurposed mtb, or any $300 garage find that 'might work.' That caveat is the concession that you recognize whatever you have might be an approximation (at best) of a Riv, but it wont have the aesthetics and you might not enjoy the satisfaction that you derive from owning something designed by a great designer. Does Riv own a monopoly on the (relatively) expensive all-purpose mass produced bike? Hell no. Co-motions are great (and more personalized that Rivs). Thorns are great. Bruce Gordons are great. But those designers are likely as idiosyncratic as GP, so you all must hate them too.
#100
Liked 3,475 Times
The deal breaker for me is price. On and off I look around for my "ultimate" touring bike and I don't think the Atlantis is it for me. I just think it's too expensive for what it is. I realize others feel differently. But I when I look at other bikes to buy, I sure as heck don't ask whether they measure up to a Riv or not.
