White Thick Slick, anybody make a comparable tire around 30mm?
Im over 200lbs but i want a white thick slick for a specialized m4 convers. Wider tire. Anything comparable?
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I was not aware that they make the Thickslick in white.
There are many comparable and better tires. What attributes of the Thickslick do you like? If it’s the completely smooth tread and big, script logo that you like, I don’t know of any others with this appearance.
If you just want a durable (but heavy) road tire in 32mm width, the Continental Gatorskin comes to mind. With the rising popularity of gravel bikes, there are many others that could work for you, just won’t have an appearance much like the Thickslick.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I seem to recall the Thick Slick being an utter train wreck as far as rolling resistance.
I’m using Continental Contact Speed tires in the 26x2.0 size on a vintage MTB. That tire is nearly smooth with a minimal diamond tread pattern, comes in a lot of sizes and widths, rolls pretty well, has a puncture layer and seems to be easy to install and remove.
Oh, actually I don’t think the Contact Speed comes in white, so that won’t help. Sorry about that.
Otto
Otto
Appreciate the replies, idk if its me but I've always had bad luck with conti sidewalls gettn cut or nail punctures. Is the sidewall of a gatorskin that thick vs the other roadie racing tires from conti?
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
They also have a reputation for terrible feel or handling. I’ve heard them described as like riding on a frozen hose, a piece of rope, or a wooden wheel. In my experience they were not that bad, but I’m not too sensitive to that kind of thing.
The Thickslicks I had looked cool, resisted punctures well, and handled okay, but were HEAVY.
Likes For Broctoon:
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,002 Times
I have had few flats with Gatorskins and other Conti tires. Thickslicks are pretty terrible tires all around they are thick and heavy but not of a ton of quality just a big logo and some colors.
Likes For veganbikes:
