Shimano XT m-772
Liked 2,758 Times
Shimano XT m-772
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20240504_165404_4e788a934246f06fde13fba54ac9fe04496597c0.jpg)
I've never set up a Shadow derailleur and was wondering what the cable routing was around the cable clamp bolt. Pictures show it with both over the top and underneath. Can almost get it to work on top but it wants to skip some gears or hesitates going down. Using it for a 105 10 speed drive. Thanks for any other insight.
Liked 4,994 Times
Are you certain the cable isn't on the wrong side of the pinch bolt?
It also might be that the cable housing is too long. I'd try to get rid of the bump where it comes out of the stop on the chain stay. But wait and see what others say about that before you go to cutting it.
And something just looks odd about how it's hanging from where it's attached to the dropout. Again, see what others say about that.
A picture with it in the big/big and the small/small might be useful. You did check the hangar wasn't ever so slightly bent?
If you're using 105 shifters, 10 speed is where they get incompatible. Road shifters require road ders and mtb shifters mtb ders. You'll need this https://www.wolftoothcomponents.com/products/tanpan to work with the mtb rear der and road shifter.
Likes For Russ Roth:
A better, close up picture of the pinch bolt would help. Here is Shimano’s tech doc:
https://si.shimano.com/en/manual/sea...&model=RD-M772
I think I have one of these on a bike but it’s not in front of me. I’ll try to check mine later.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/646x677/img_8494_c9441ecb2ede679f1a0cc66cb0898b7d5893880c.jpeg)
Likes For bboy314:
Likes For bboy314:
Likes For bboy314:
Liked 2,758 Times
Liked 2,126 Times
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/img_5156_5d8674f76db039453398fe61905a0c919a530d65.jpeg)
Likes For t2p:
Likes For grumpus:
Liked 2,758 Times
So just a final update. This derailleur came off a 9 speed mountain bike running a 11/34. It was having issues before I replaced it so I just figured something wasn't compatible. On this recent setup it was catching gears but would not shift down without a double click. Getting ready to replace it with an older xt I noticed the B screw was turned in pretty far. I backed it out almost all the way and now it hits shifts like advertised.
Likes For curbtender:
