Campa 10 Ergos with Sram 10 FD?
Quick question. Are Campagnolo Record 10 speed Ergopowers compatible with Sram Red 10 speed front derailleurs? I know that the rear derailleurs are; but does it work for the front derailleurs, too?
The rear derailleurs aren't compatible.
The fronts shouldn't be a problem - very similar cable pull.
I was running Veloce 10spd ultrashift levers (which are more similar to the 11spd levers) with a Sram force front derailleur (with Yaw) and it shifted fine and the force on the lever seemed about the same as genuine campy.
Likes For bluehills3149:
