Should I be worried?
Bikes: 2013 Cannondale SuperSix - 1998 CAAD3 R500 - 2012 Demo 8 Carbon
Quoted: 13 Post(s)
This is the seat tube of my SuperSix.
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
Take it to your nearest Cannondale dealer and have them inspect it.
Quoted: 13 Post(s)
I did, and the sales rep glanced at it and said it's fine. Didn't even take a look really-- just stood there and looked. I don't know if they try and avoid warranty claims or what… thought it was a bit odd.
is it a scratch in the paint??
was there an incident like a crash, the bike falling over, or something heavy falling on the tube??
it would be unusual for the tube to split like that from just riding unless there was a major defect in the manufacturing of it.
thats the seat tube? I was told by my lbs that there is very little weight supported by that tube due to the diamond shape design of frames. and its just there to mount your front der and a water bottle to.
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
2000 litespeed Unicoi Ti, XTR,XT, Campy crank, time atac, carbon forks
Quoted: 13 Post(s)
Quoted: 126 Post(s)
Liked 55 Times
And what did the sales rep who did not carefully examine the bike say that this was from? If it is under the clear coat, it could be delamination of the CF. Can you squeeze this area and have any deflection or sound?
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
If you lightly tap the seat tube with a tire lever, does the sound change tone around the area in question?
BTW, have a trusted/competent mechanic take a look at it. A sales rep might not be the best person to ask.
I could be wrong but it looks like a surface scratch to me, it's uneven and goes against the grain, probably a transfer from whatever got up against it? Have you tried using anything to rub it out like a small dab of wax or acetone? If it turns out to be a "crack", contact Cannondale about it and bring the bike back in to the shop. If the 1st guy blows you off again, ask for the manager or find another Cannondale dealer. You paid good money for the bike that includes a frame warranty so use it! I believe the shop gets paid to transfer all of your components to a replacement frame so they should be willing to help.
Quoted: 13 Post(s)
Quoted: 659 Post(s)
Liked 595 Times
I'd push for a claim on this. If under warranty, get on the phone. Whether it affects reliability is primary but you also have a bike with a tough resale value.
Quoted: 13 Post(s)
I just ride and admit to knowing nearly nothing about carbon.
Hey, we all gotta start somewhere. Better to be worried and ask than actually having it be an actual manufacturing defect and having the crabon asploding while descending at 45mph.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
A tap test shows actual damage but it won't show something that has the potential to later weaken the material.
If a scratch gets worse over time, it was never simply a cosmetic scratch.
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Quoted: 67 Post(s)
Liked 7 Times
Whomever the knucklehead who looked at it was, well guess what? If it fails it is on you. Do you know who you talked to? That will also matter.
The photo is pretty bad. I can barely make out what it is. But if there is a hint of a frame issue, Cannondale looks at it in the shop.
Quoted: 67 Post(s)
Liked 7 Times
Quoted: 67 Post(s)
Liked 7 Times
I love it when people advise to call the manufacturer, direct. That is the wrong thing to do.
BTW...I don't think I saw if you are the original owner?
It looks like a "seam". One possible defect that this could be is what is called "delamination". Once the frame is layed up in the mold, pressure is often applied to force the layers of CF against the outer surface of the mold. One of the things this does is force air out from between the layers. Tiny air pockets can start and propagate cracking between the layers. A defect like this leading to a fatal crash of an aircraft made by Russia's Sukhoy, led them to drop out of the civil aviation market when it was discovered that the cure temperature and pressure of the laminated wing spar was out of spec. on an entire lot.
It could be nothing more than cosmetic, but get it checked. The attitude of the sales rep sounds like some I have gotten at Performance Bikes, where I often get the "Ya want to super-size that?" treatment. Get an expert to look at it.
Quoted: 659 Post(s)
Liked 595 Times
I would still be trying. There shouldnt be any dissatisfaction with a situation dealing with the main component of a bike. If it's a problem with topcoat, cool. If this is a crack or defective mold....time for satisfaction. CF isnt Alu or steel and certainly not in the same price range.
