Bike Recommendation
Quoted: 9 Post(s)
Bike Recommendation
I am looking at possibly purchasing another bike, but trying to decide on what to do. I currently have a road bike, and a mountain bike, but I don’t really feel like either of them are going to do what I’m interested in doing. Basically I want some thing that I can ride through town or even do some mild distance on back roads but also something that I will be able to take on a fairly smooth gravel trail system (Ahnapee Trail in Wisconsin if anyone is familiar) for anywhere from 10-40 miles. I see a lot about cyclocross and gravel bikes but the info is pretty overwhelming for a newbie such as myself. My road bike doesn’t get ridden much because honestly our roads kind of suck and it’s a little rough with lower back issues so I’m thinking about selling that one. I know I could technically use the mountain bike but not sure how that would be for longer distances. Any recommendations on which type or even specific models? Looking for something fairly entry level but not a department store bike. I’ve had Giant, Specialized, and mostly Trek in the past. Thanks in advance for any advice.
Likes For prj71:
Expired Member
Quoted: 3731 Post(s)
Liked 5,599 Times
Most brands have "gravel" bikes at various prices. Seems the obvious choice.
Likes For shelbyfv:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 597 Post(s)
Liked 833 Times
I ride a giant TCX cyclocross bike for that exact kind of riding.
Cross bikes are more racy that gravel bikes, more aggressive geometry… it’s as fast as my road bike with road tires.
Gravel bikes are more relaxed, have more places to mount stuff, and can handle a little wider tire.
1x drivetrains are great for these applications.
If I had to have one bike it would be a cross bike.
Likes For Jughed:
Habitual User
Quoted: 5039 Post(s)
Liked 8,273 Times
As noted by others, it sounds like a gravel bike would be a great fit for your described use.
An important factor…what is your budget?
For me, my gravel bike is my most versatile. It excels on dirt roads and rough pavement, is competent on moderate singletrack, and is efficient enough on the road to not feel like I’m pushing a pig.
Likes For Eric F:
Quoted: 6292 Post(s)
Liked 4,885 Times
Maybe you just got a crappy road bike for your conditions. Wider and better rolling tires will go a long way to fix a crappy ride if your bike can handle them. If you are on very budget friendly tires it's going to be a rough ride no matter what you have.
But this might also be to your liking
Checkpoint ALR 5 - Trek Bikes
And it comes in many different tier levels with all the way up to more money than I could comfortably afford to pull out of my pocket. During a ride I was doing earlier this year, I met a guy on a Checkpoint that was loaded down with paniers on the front that was doing a 444 mile trip and he said he really enjoyed it. His was one of the carbon fiber versions.
Even though it's marketed as a gravel bike, it apparently does well for touring too.
Sunshine
Quoted: 11037 Post(s)
Liked 7,588 Times
Road bike isn't ridden because roads suck too much
MTB is overkill for type of desired riding.
Desired rides would be in town and back roads as well as crushed stone trail.
Unsure if a gravel bike would be best even though it's designed for bad roads, gravel roads, etc.
What?
If there are too many options, pick a price range and see what's in stock at shoes near you in your size. Call em and go to places that have inventory in your price range and size. You will immediately narrow it to maybe 5 bikes just by calling.
A bike that can handle 38-45mm tires will work perfectly for you. They all have slightly different geometry and feel different as a result. Some will feel slow steering, others fast steering. There is no right or wrong, get what you like.
Buy 2x or 1x drivetrain. There are upsides and downsides to both. Again, no right or wrong. If you have a preference, then that helps further narrow the choices. If you don't care, then buy what fits best.
What?
Sunshine
Liked 7,588 Times
Habitual User
Liked 8,273 Times
Sunshine
Liked 7,588 Times
Quoted: 4505 Post(s)
Liked 4,991 Times
Expired Member
Liked 5,599 Times
Yep, it sets off ZeroGPT.
Likes For blacknbluebikes:
Quoted: 9 Post(s)
Thanks to all for the valid advice, I'll check out some of the specific models you recommended. Right now I have a 2015 Giant Defy 5 which is definitely a cheaper entry level road bike and a Specialized Rockhopper MTB. I'm definitely not AI, not sure what gives off that vibe. I keep wanting to find the right type of riding. I enjoy riding, but I have a screwed up back and can't seem to find my fit. Been trying to gain some traction (no pun intended) for several years I just havent found a sustainable type of riding other than my road bike on my trainer in the basement doing a virtual ride along with someone on Youtube I originally joined trying to help my daughter when she wanted to do Triathlons, then tried to find something myself. I've recently dropped about 50 lbs, I'm feeling better and want to ride. I grew up being a runner but that's just not in the cards for me anymore and to me biking is somewhat of a substitute for that. I've also tried swimming, and want to get into Kayaking. Once again, thank you sincerely to the ones who took the time to answer my question and give some valid suggestions.
Quoted: 9 Post(s)
Quoted: 9 Post(s)
Quoted: 7666 Post(s)
Liked 3,539 Times
Looks good ... what do you think?
Sunshine
Liked 7,588 Times
Cyclocross bike. Looks like a size 53?...tough to tell with the tube sizes. If so, the geometry will make for a relatively neutral feel compared to the wide range of drop bar wide tire bikes currently on the market. Steering will not be fast and twitchy, but also not slow and sluggish. Chainstays arent too tight and will help with a more relaxed feel compared to a tight geometry road bike. Based on bottom bracket drop measurement, he bike will feel like you are 'sitting on top' of the bike more than 'in' the bike. Hopefully that makes sense.
The shifters are not a shape that is still made- it was pretty unpopular, but based on reviews from 5 or so years ago, they consistently worked fine. It has hydraulic brakes which is nice. 2x10 drivetrain is plenty good too.
The most important thing when looking for a used bike is whether if fits properly or not. If you are compromising in your mind during a test ride, it will suck once you take it out for any extended length of time. A different stem length or bar shape is no big deal to change, but the actual feel of the bike- that has to be something you really like.
After that, if the components are in good working order and you think the price works, then buy it and ride! No idea if you can fit tires wider than 35mm into the frame, but if 35s are good enough then it looks like it would fit your criteria.
Likes For mstateglfr:
Habitual User
Liked 8,273 Times
If it fits in your budget, it seems like a good place to start. Felt is a well-known and reputable brand.
