Dura Ace 7s Uniglide hub help - Pondering custom build
Quoted: 2215 Post(s)
Liked 4,100 Times
I've still got the 7s Dura Ace Uniglide hubs floating around which are 126mm rear spacing. I also want a good 126mm wheelset for use on the Krapft bike. What's on there are pretty low end ones I had around from some other bike. I just want to make sure I get my hands on the right uniglide cassette first. Does it have to be a 7 speed or will an 8 speed uniglide cassette fit? This bike is running friction DT shifting so spacing between cogs is not a concern. Any thing else I should be considering if I go this route?
My thoughts are lighter polished silver rims with the hubs to keep the same look I have now but with a better quality wheelset. I have a builder in mind already as I've never learned this skill.
I just don't want to go pay stupid money for a cassette that won't work with this hub.
thanks!
The middle hubset is the one in question.
I want the wheelset for this bike.
thanks!
Steel is real...and comfy.
Blamester
I have the tricolour hubs. I filed the long tab on a 9 speed hyperglide cassette. I used 6 of them and secured it with a lockring. Which I got of a bsa bb.
I had to use a spacer at the back of the cassette to get it snugged up and centered.
Thousands of km and no problems
Quoted: 1090 Post(s)
Liked 403 Times
I don’t believe you can run an 8 speed cassette on the 7-speed Dura Ace 126mm 7400 freehub. You probably could run non-DuraAce 7 speed cassette for all except the smallest lockring cog. Usually you can find Dura Ace Uniglide lockring cogs on eBay. I agree that new old stock 7 speed Dura Ace 7400 cassettes are going to be scarce or expensive. A clean used one might be easier to track down or you could improvise one from individual cogs.
ambulatory senior
Quoted: 1848 Post(s)
Liked 3,180 Times
If you don't mind modifying the cogs you can use any uni or hyper cogs. The modification is 5 minutes max with a file in a vice. Then you use whatever spacing you need to use with your selection of cogs. I run 14-36 on a tricolor hub. 7 speed touring.
Likes For 52telecaster:
Tinker-er
Bikes: 1956 Rudge Sports; 1958 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1971 Raleigh Twenty; 1994 Breezer Lightning XTR, V4 Yuba Mundo aka "The Schlepper", 1987 Raleigh "The Edge" Mountain Trials, 1951 Rudge Aero Clubman
Quoted: 115 Post(s)
Liked 161 Times
You can run up to 7 cogs on the DA Uniglide, and you don't need any specific cassette but you will need the correct small cog for the lockring. A DA cassette can be found but cogs is cogs when it comes to the Uniglide system, so buy whatever you can find, then make sure you have correct spacers and a correct 11 or 12 tooth lockring and you’re good to go. Don’t pay a ton to get an actual DA cassette when it’s the same thing as a Tourney one, just champagne color. Some of the 600 Uniglide hubs used the same small lockring, so you can also use them in your search.
I just finished building up a 1994 Breezer Lightning XTR with a 7 speed Uniglide cassette and it shifts perfectly with my XTII thumbshifters. Have fun and happy riding.
Likes For PhilFo:
Freewheel Medic
Quoted: 1317 Post(s)
Liked 1,811 Times
I've had success building an 8-speed cassette on a 126mm UniGlide freehub by using 9-speed spacers.
Bob
Bob
Likes For pastorbobnlnh:
Have you got your hands on the special Dura-Ace #1 and #2 cogs that fit this freehub? The #1 (Dura-Ace only) cog is a smaller diameter than the standard Uniglide #1 cog, and the #2 cog has 'tabs' that face inwards to engage with the splines. These cogs are basically unobtainable.
The remaining 5 cogs - if you have a flat file or a Dremel, then standard Hyperglide cogs can be made to fit, and in terms of shifting, are a big improvement over the clunky Uniglide cogs.
My advice: use a cheap 126mm OLD 7-speed Shimano rear hub that is Hyperglide-C cassette compatible, and save yourself a whole bunch of misery.
Likes For Dave Mayer:
ambulatory senior
Liked 3,180 Times
Liked 4,100 Times
Recovering Bikeaholic
You can also replace the Uniglide freehub with a Hypergljde freehub (Sheldon Brown shows how to do this), and then you'll have better luck finding a variety of cassettes.
Yes, you could possibly find a Hyperglide-compatible 7403 freehub (rare as the Holy Grail), by first removing the old freehub with the equally rare TL-FH10 freehub remover tool. But since the 7403 freehub only came in a 8-speed version, then you would not achieve the objective of 126mm OLD.
BTW: the 7403 freehub is not Hyperglide-C cassette compatible.
Again, these rear hubs are only useful as paperweights. I know, I have several.
www.theheadbadge.com
Quoted: 2338 Post(s)
Liked 4,031 Times
-Kurt
Death fork? Naaaah!!
Top
Liked 4,100 Times
Guess what I found!
Likes For jamesdak:
Freewheel Medic
Liked 1,811 Times
I was digging through my UG spare cassette sprockets last week and I do have some spares. Unfortunately, most are not the DA silver. I even found some DA threaded sprockets. Most were for 6-speed cassettes. I'm hoarding the the 7-speed ones.
Bob
Bob
Bikes: 1984 Gitane TdF, 1986 Look Équipe, 1983 Colnago Super
Quoted: 102 Post(s)
Liked 118 Times
Nice thread. I hope this question is not too much off topic. Can I change individual cogs on my 7-speed Uniglide cassette?
I have one that came as 13-14-15-18-21-24-28, so a couple 1-tooth jumps and a four 3-tooth jumps.
Wouldn't 13-15-17-19-21-24-28 with the four 2-tooth jumps be "better"?
Most of my rides are in the hills.
Thanks
Thanks
Insane Bicycle Mechanic
Quoted: 744 Post(s)
Liked 520 Times
Thanks
Thanks
Finding individual Uniglide cogs is tough now. You might not be able to find what you want in the correct silver color, but all Uniglide splined cogs are the same inside diameter. Swap to your heart’s content.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Ride, Wrench, Swap, Race
Quoted: 1476 Post(s)
Liked 1,138 Times
The 15-18t jump is ugly, I draw the line at 13-15-17-20... which appears on countless build of mine using mostly the 13-28t 6s Uniglide freewheel.
Freewheel Medic
Liked 1,811 Times
I found another 7-speed Dura Ace threaded UG sprocket yesterday! Doing so brought on a natural high.
Original dusty 13-23 UG cassette on my Schwinn 974. I switched it to 14-25.
Yesterday I also started cleaning the old glue off the rims of a Dura Ace UG wheelset I recently purchased. I'll probably build the cassette as 14-16-18-20-22-24-26.
Bob
Bob
