WTB Shimano 9 speed triple FD
Quoted: 212 Post(s)
Liked 202 Times
Need a triple FD for a 9 speed Simano 105
Or something similar that would work.
It's replacing Shimano Tiara. Spring is broken.
I have a thread in the mechanic section.
Thought it was the brifter !!
Quoted: 417 Post(s)
Liked 978 Times
These tend to break at the spring stop like that. Microshift makes a good replacement. Otherwise Shimano Claris or Sora have options to work.
Likes For bboy314:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1301 Post(s)
Liked 745 Times
Search for a Shimano FD-5503.. they are Specific to 9sp. and work great.
just avoid GRX, and Tiagra 4700, or many newer Dura-Ace models too. they use a different pull ratio.
the "3" at the end of the numerals means it's a Triple...
Likes For maddog34:
Quoted: 212 Post(s)
Liked 202 Times
Learn something new every day.
3 at the end means triple
SE Wis
Quoted: 2754 Post(s)
Liked 3,422 Times
Liked 745 Times
https://www.modernbike.com/front-der...rds-and-mounts
and the "3" isn't always the last numeral for a triple .. some color schemes may change that.
best to also compare the mechanical appearance of the mech when replacing one.
Likes For maddog34:
SE Wis
Liked 3,422 Times
Clamp type and size aren't deal breakers. Larger clamps can be shimmed. Braze on adaptors are readily available. Pull adaptors are also available, but in my eyes a kludge.
I personally often buy braze ons as with an adaptor will fit numerous frames.
Quoted: 860 Post(s)
Liked 1,101 Times
Likes For Crankycrank:
