Hub Offsets - Critical?
Hi,
In another thread I talk about replacing a damaged hub on my rear rim brake Zipp 404 wheel. I am having a hard time finding a suitable 20h hub. I have found a Taiwanese hub but the flange offsets are different. Other than affecting spoke length how critical are the flange offsets to wheel performance or safety? This is on a Giant Propel that will be raced.
Thank you
Rich
Thank you
Rich
Quoted: 6195 Post(s)
Liked 4,810 Times
Critical for safety? Probably not going to make the bike so unsafe that you'll come to a terrible demise.
I'd think they'd have more to do with what number of speeds you could have on the bike for any particular desired OLD.
Certainly a wheel builder will be along soon to answer.
Really Old Senior Member
Since you want to keep the numbers a secret, run them through SpoCalc.
Original hub Zipp 188 V8
From a quick measure of the old hub it looks like the White Industries T11 has the same offsets. (Can't find one though)
Center to left flange 35mm Center to right flange 18mm
Then there is this:
https://www.cycletaiwan.com/circus-m...-rear-hub.html
Not a confidence inspiring name. But it is cheap, 20H, rim brake, and light. I can't seem to figure out the offsets from this drawing.
Also, I am 6'+ and 155 lbs. Not a sprinter.
Thanks all!
Quoted: 1562 Post(s)
Liked 1,734 Times
In general a rim does not care about the hub's flange offset.
The rare exceptions would be like HED, Mavic Cosmic carbon, Aeolus, or Flo wheels with soft carbon fairings, where the spoke must go through the hole in the carbon fairing at a particular angle. In that case you need to find a hub that has similar flange diameter and offset as the original.
Liked 1,734 Times
No- the ZIPP wheels all use hard, structural carbon fairings. The nipples are anchored in the carbon.
In the soft fairing wheels the nipples anchor in the aluminum rim. The carbon is purely non-structural. There are holes in the carbon for the spoke to go through.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
posted to your previous thread... rosefarts
With a mighty wind
Quoted: 937 Post(s)
Liked 715 Times in 416 Posts
https://www.bikehubstore.com/RAR12-p/rar12.htm
20h in Black, competitive weight, competitive price. I’ve used a few other Bitex hubs and I’ve always been pleased with the quality.
With a mighty wind
Quoted: 937 Post(s)
No secrets! But I will do that when I have time. More background:
Then there is this:
Thanks all!
Then there is this:
Thanks all!
Based on the 48.22mm & 9.3mm figures, center to flange distance is: DS 14.81mm (48.22mm divided by 2 minus 9.3mm) and NDS 33.41mm (48.22mm / 2 +9.3mm), inside of flange to center point between the OLD.
Adding half of the flange thickness (3mm / 2), we get: DS 16.31mm and NDS 34.91mm, center of flange to center point between the OLD. This should result in a relative tension of 46.72 NDS to DS (16.31mm/34.91mm).
For comparison to Shimano's method of measuring, (outside of flange to outside of flange), we add full flange thickness of 3mm to each side: DS 17.81mm & NDS 36.41mm. This should result in a relative tension of 48.92 NDS to DS. Shimano 11 speed road hubs are about the same with regards to relative tension. Shimano's hubs are slightly wider between the flanges, (about 3mm), so the bracing angle is slightly better.
Don't know how the measurement of the various other hubs mentioned were taken (inside/inside, center/center, outside/outside).
Not sure about where the NDS/DS relative tension reaches a point where it becomes a problem with regards to wheel strength or stability. Believe that 'hoop strength' and maximum tension that the components can withstand would play a part.
Rich
With a mighty wind
Quoted: 937 Post(s)
With a mighty wind
Quoted: 937 Post(s)
Ordered! I am still looking for other options like the T11 but at least this is on the way.
Thank you
Based on the drawing the hub is 48.22mm between the flanges (inside to inside) and the offset is 9.3mm (sometimes referred to as dish). Seems that the drawings uses a " , " in place of a decimal point, see this in some number listings in non-USA applications.
Thanks
Rich
Thank you for working through this. It seems like they didn't make much effort in making that drawing clear. I don't understand relative tension, that is new to me. I have ordered a hub with the same offsets as the original to avoid deviating from the original.
Thanks
Rich
Thanks
Rich
For example, if the hub has flange spacing that gives a relative tension of 50%, the left side will have half the tension of the right side. So, if the wheel is tensioned to 120 Kgf on the right side, the left will be about 60 Kgf,
The relative tension (also known as tension ratio) is an estimate of the left side tension in relation to the right side.
Rich
I have ordered the hub mentioned above. It has 2.3mm spoke holes, can I use 2mm diameter spokes with that hole diameter? The current plan is to buy CX-RAY spokes and reuse the existing nipples. The original spokes are 2mm diameter.
Also I am using SpokeCalc, it asks for "width between holes" and "offset spoke bed" for rim parameters. I am assuming these are both zero for these Zipp wheels, is that correct?
Rich
Rich
Rich
Rich
Quoted: 4206 Post(s)
Liked 3,870 Times
Rich
Rich
AndrewRStewart
AndrewRStewart
Quoted: 499 Post(s)
Liked 434 Times
Then there is this:
Then there is this:
I disassembled the wheel (Older Zipp Speed Weaponry 404) and there are no spoke washers. Is it normal to not use them on these older Zipps?
Liked 3,870 Times
Spoke washers, for the elbow/flange fit, are about elbow length WRT flange thickness far more than hole diameter. One wants the spoke "body" (the main shaft) to be snug against the flange if at all possible. Spoke washers are placed between the spoke head and the flange as needed. 2.6mm holes will work fine with 2mm spokes assuming the elbow length and flange thickness are also good.
Or are you asking about nipple/rim washers? These are rim driven, not hub dependent. Andy
AndrewRStewart
AndrewRStewart
All back together and ready to Rip!
Thanks all for the help.
If I wanted to make a living as a wheel builder I would have to charge by the hour.
Rich
Rich
