bar end shifter question
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Liked 203 Times
I have a set of Shimano 105 bar end shifters on my touring bike.
I noticed the front shifter was loose so I removed the lever and tightened the shifter wedge and when I reassembled the unit it sounds like it is indexed now, it wasn't when I took it apart.
I may have just tightened the swivel bolt but there seems to be an overly complicated washer/spacer in there..can it be repostioned to go either index or friction?
Mike
Mike
"ready to navigate"
"ready to navigate"
bykemike, My 8S bar ends came out the same way, but it suits me fine. As I understand it, I caused the 'problem' by not installing the washer properly and could get rid of the detent by rotating it 90 degrees.
Brad
Brad
Liked 203 Times
I'm going to rotate the washer tomorrow, I just noticed on an eBay ad for the shifters.."friction or indexed"
Thx
Mike
Thx
Mike
"ready to navigate"
"ready to navigate"
Insane Bicycle Mechanic
I may have just tightened the swivel bolt but there seems to be an overly complicated washer/spacer in there..can it be repositioned to go either index or friction?
Mike
Mike
If you want to check, that "washer" (what Shimano calls a "lever boss cover") should be positioned with the fat tab pointing down, at right angles to the lever body. Take a look at this PDF for a hint:
https://techdocs.shimano.com/media/te...9830628723.pdf
Jeff Wills
Jeff Wills
Mike, I left mine with the detent because I discovered that shifting from the 44T to the 32T only required hitting the detent, so almost like indexed, but not quite. Going from the 22T to the 32T I shift to just beyond the detent. Something you may like if it works out for you.
Brad
Brad
gemini
Bicycle Mechanics
7
07-16-15 06:49 PM
lungimsam
Bicycle Mechanics
2
07-26-12 12:14 PM
special_k
Bicycle Mechanics
7
03-07-11 04:06 PM
sunstealth
1
07-16-10 07:35 PM
