Problem with cassette shim
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
I bought a wheelset that was 8,9,10 speed compatible and put a 7-speed cassette on with the requisite spacer. I got the spacer from my LBS. I had shifting and skipping problems on the 32 tooth sprocket and discovered the cause was gross runout. Turned out that the cause of the runout was that the spacer under the cassette had too big an inner diameter and would shift to one side and almost go past the shoulder on the hub. I have not had much luck finding other spacers with a properly snug inner diameter. I ended up dismantling another perfectly good -- but currently unused -- cassette and using the #3 gear plus a 1mm shim for the spacer. No runout whatsoever, shifting is perfect and no popping. Of course it looks very wrong and I have lost a perfectly good cassette to do this.
Any suggestions on where to find spacers with snug ID that will fit properly?
Don in Austin
Don in Austin
Quoted: 1951 Post(s)
Liked 948 Times
Many 7-speed cassettes have the largest 5 or 6 cogs held together with bolts or rivets and the bolt/rivet heads can interfer with seating the cassette if the spacer is added behind the largest cog. You could remove the bolts but I had good results installing the 4.5 mm spacer between the smallest cog and the lockring which avoids the problem entirely.
Quoted: 11 Post(s)
Don in Austin
Liked 948 Times
mechanically sound
OP: PVC pipe?
Liked 948 Times
The smallest cog does stay on the outside of all of the other cogs but it doesn't have to be right up against the lockring. The 4.5 mm spacer can be installed outside of the the smallest cog and the lockring can tighten down against it. The lockring, if torqued to spec, will remain tight with no problems.
Quoted: 9 Post(s)
mechanically sound
This is what I mean. I've never seen a cassette with a small cog that can slide down the freehub body-not even my seven speed shimano cassette. Perhaps some cassettes have a non-lipped small cog?(in which case the outer spacer sounds ideal).
Liked 948 Times
However, I just checked several 12 and 13T Shimano 7, 8 and 9-speed small cogs and all of them slid completely down over a Shimano 8-speed freehub body so they would all work with the outboard spacer too.
nickw
Bicycle Mechanics
18
03-09-15 07:07 PM
tjc4golf
Bicycle Mechanics
10
08-07-11 02:24 PM
