Which SRAM groupset to get for my new commuting bike?
Hello all,
I'm putting together a bike from an Specialized Allez e5 frame, and, as the frame is all black, I'd like to put in a groupset that's also black, so I'm thinking to go with an SRAM; specifically, an Apex (lowest in the line), however, now I'm having second thoughts as to whether I should pony up for a more expensive one in terms of functional quality (eg. the quality of the brakes).
I've seen builds on this 2013 frame are typically being done with the SRAM Red (top of the line), but since the main purpose of the bike will be daily commuting and all those components will be uninsured, I'm not sure if the expense (for a more expensive group) would be justifiable in terms of me getting more reliable-efficient braking/much nicer gear shifting etc.
Practical issues mostly is what I'm concerned with (not thinking of weight shelving as main priority).
I had some Tektro (stock) brakes in a mtb last year and almost ended up under the wheels a Ford truck with them once (changed them MINUTES later for some Shimano ones, and it was night/day difference), so I want good and reliable mechanics this time. Still it'd be good not to break the bank, specially if it's just for saving a small amount of grams.
Thanks much for your opinions and any suggestion
Braking, SRAM Force is the best bang-O-buck out there, their brakes are on same level as Dura-Ace (7800/7900) which I find the best in the world.
SRAM Rival for a commuter, bit below Force but very durable and high quality.
I have 1 bike with DuraAce brakes and three with SRAM Force, it gets no better. Tektro are a fill in brand to meet price points of complete bikes.
You often see complete bikes in the $2700-$3400 range spec-in Tektro brakes and a FSA Gossamer crank to meet price points. The difference can be substantial to the manufacturer.
serious cyclist
Bikes: S1, R2, P2
Liked 3,685 Times
To my understanding, the main difference between Apex and Rival is Apex has plastic brake levers while Rival has carbon. Seriously. They cost almost exactly the same. Go Rival.
Dunno if this is still the case, but in past years the Rival brakes lacked the micro adjustment that was included on all other SRAM brakes, including Apex. But not everyone uses it so you may not care.
With SRAM, unti you get to the Red, the differences are mainly in lighter materials as you go up the line. For a commuter I don't see that as a concern as all SRAM groups are light.
I'd go with all Apex. Well, Apex with a KMC chain and shimano FD because they work better.
double0eskimo
Singlespeed & Fixed Gear
13
10-10-12 09:58 PM
double0eskimo
Road Cycling
5
10-09-12 08:28 PM
