Bridgestone XO-2 1993
Hi all, does anyone know the distance between the canti posts on the fork of a 1993 Bridgestone XO-2? From reading through past threads it sounds like the spacing between the posts on the forks of older touring bikes was narrower than the standard, contemporary width and that this can cause compatibility issues with newer components (such as mini-v brakes or front racks that mount onto the canti bosses). Wondering if the 1993 XO-2 is closer to the wider, modern standard (77-85mm) or the narrower, older standard (55-65mm). I believe the measurement is taken from center to center of the two posts. Thanks for any info.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,529 Times
The Bridgestone catalogs are online somewhere; rivbike.com? I’m sure you can google it. Good luck and be sure to post pics! 🙂
I don’t have a 93 XO-2, but I do have a 92 XO-2. Spacing on the fork is 80mm, 83mm on the rear stays. I can’t imagine they would’ve gone back to the old spacing the next year so probably fair to assume it’s the modern spacing.
Happy banana slug
Liked 1,529 Times
Cant say I’ve ever seen cantilever post spacing in a catalog for any manufacturer, ever. Have you?
Quoted: 3810 Post(s)
Liked 6,705 Times
Probably best to post this question over in the iBOB Google group.
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 30 Post(s)
Liked 82 Times
i happen to have a bridgestone 1993 XO-2 - took some measurements for you
fork 64mm
rear 85mm
also have a 1992 XO-2 and got these measurements
fork 80mm
rear 88mm
i was surprised to see the frame / fork changed quite a bit from 1992 to 1993
photos might be slightly off - had a hard time getting a good photo while holding the ruler perfect center to center. but my typed out info above is dead on center to center
hope that helps !
fork 64mm
rear 85mm
fork 80mm
rear 88mm
hope that helps !
