Shifter cable for Campy Athena circa 1995
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
The shifter cable on my 1995 Marinoni broke inside the shifter this morning (haven't yet tried to fish out the end.)
I seem to remember it not fitting quite right when I installed it. Is there a Campy specific cable I should have used?
Any tips on getting that broken end out easily?
Quoted: 1074 Post(s)
Liked 295 Times
Yes There are Campy specific shifter cables that should be used. Campy - for whatever reason - prefers a shifter cable where the ”button” at the end of the cable is a tiny bit smaller than for Shimano shifters. Using the wrong kind may cause it to lodge near permanently in the shifter, becoming a real challenge to remove.
It’s possible to file down a Shimano spec shifter cable end to fit nicely in a Campy shifter.
Likes For dabac:
Quoted: 159 Post(s)
Liked 133 Times
Now that you mention it, I think I did file down the end. Perhaps I nicked the cable itself, leading to the failure.
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
I've got some Jagwire ones that worked out fine, forget where I ordered them from. Can get singles from BikeRecyclery (but don't browse too much, too many tasty things on that site!): Campagnolo Shifter / Derailleur Cable: 2000mm - Stainless - 8/9/10/11/12s (NEW) - Bike Recyclery
Quoted: 159 Post(s)
Liked 133 Times
Thanks for the info!
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,099 Times
Jagwire is what I use
https://www.ebay.com/itm/13137316735...53.m1438.l2649
I recently got a used Campy 10 speed group and the shift cables were stuck even though I don’t think they were Shimano ends. I was able to drill them enough to loosen and pop them out. I’ve come across cable ends stuck in down tube shifters a couple of times and it’s usually a death knell, never been able to get one out.
Quoted: 1641 Post(s)
Liked 831 Times
Yes, always remember to file or sand the heads down so they have at least, a small amount of gap, all the way around when they sit in the shifter cable head well. If you can spin the cable head freely in the well by twisting the cable, it should be enough. I also put a dab of grease in the head wells, before installing the cables, to fight corrosion that will seize the head to the well.
Quoted: 159 Post(s)
Liked 133 Times
