What is a gumwall tire?
Bikes: 1988 Cannondale SR500,TREK Mendota 2011
When I bought my Dawes Galaxy new in 1969, it had gumwall tires, what is gumwall exactly?
I have my 1986/7 Schwinn Traveler, and now I have black Specialized Tri-Sport tires it
Senator from Secret
Quoted: 5 Post(s)
It doesn't matter... you are going to sell me the Galaxy...YOU ARE GOING TO SELL ME THE GALAXY...YOU ARE GOING TO SELL ME...
Hair Club Member
Bikes: '86 Miyata 310 '78 Raleigh Sports 3-Speed
Carbon black is added to harden rubber - the normal color of rubber is pale to tan. The softer sidewall compound is supposed to decrease rolling resistance. It is, however, more vulnerable to damage from ozone pollution.
Senator from Secret
Quoted: 5 Post(s)
That is true. So leaving your bike for years in the basement with the furnace and water heaters can make them break down and look terrible. This is internet hearsay. I don't know the science.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Per Frank Berto in his 1988 book on upgrading road bikes, he differentiated gumwall from skinwall tires by the amount of rubber on the sidewalls. Skinwalls were high end road tires with minimal rubber on the sidewall and usually you could see the casing fibers through the rubber. Gumwalls were cheaper and heavier tires.
Gumwalls used thicker rubber on the sidewalls and were lower performance, and less expensive, tires. This was regardless of sidewall color. From what I have seen probably still true today. Most of the high puncture resistance tires and cheap tires would be considered gumwall construction while light weight performance oriented tures would be considered skinwall tires.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Senator from Secret
Quoted: 5 Post(s)
Hello
Much later I worked at a facility that produced ozone for disenfection. They first distilled oxygen from the air and then passed it through an electric arc to produce ozone. O3 is short lived and rapidly decomposes to O2.
Is this what is happening in a basement with gumwalls - I don't know. However I would not put an ozone generator in my basement. They sale these things for the home for odor control.
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
Exactly correct. At a distance, gumwall and skinwalls look pretty much alike. There's a world of difference in weight, ride quality, and road feel between the two.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
My juinor college engineering instructor worked on PT boats during WW2. He told us of a rather difficult problem he had to resolve of why the rubber based wire insulation in one of the compartments would rapicly break down causing all kinds of erratic problems. After much research it was determined to be ozone (0sub3) which was formed from oxygen in the air passng over an electric arc. The cure was to ventilate. FWIW he told me he worked on JFKs boat.
Some years ago, my Honda Hawk GT mororcyle's tires suffered from accelerated dry rot after just a little bit over a year parked next to our apartment building's mechanical room that had all sorts of big electric motors running in it all day long with their brushes producing lots of ozone. I knew that the damage was from the mechanical room ozone because only the side of the motorcycle that was always faced towards the door louvers to the room had ost of the rot damage. Bad thing was, the damage ususally creeps up on you and you susually notice things like this when it's too late. Had to replace both perished tires (but still with a lot of good tread left) on the bike to keep it safe.
Chombi
Guest
Posts: n/a
Quoted: Post(s)
Does it bother anyone else that 'skinwall' is used to describe not only the amount of gum rubber on tire sidewalls, but also refers to the color of the tire? 'Blackwall' is black, 'skinwall' is- non black.
Last time I checked, skin color has a range of hues.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Yeah, I would avoid using "skinwall".
Older readers like me might not question the use of the term, but younger people could find the term to be incorrect or meaningless.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I dont think skinwall is a confusing term... to me it just means less rubber on the sides. If I saw skinwall tires that were red, I would probably say red skinwall.
