Ultegra 6700 Crankset compatible with Tiagra 4700?
Hi All
I have a Boardman bike with a Tiagra 4700 Groupset.
Please could someone tell me if I can integrate this with an Ultegra 6700 Crankset?
I hope so as I've just bought it!
I've just seen some articles suggesting that they possibly won't be compatible.
Any help would be appreciated
Quoted: 514 Post(s)
Liked 448 Times
The cassettes are cross-compatible and I've heard of no indications that the cranks would be.
Quoted: 6195 Post(s)
Liked 4,810 Times
You might have an issue with the front DR. But since you already got the crank all you have to do is slide the old crank out of the BB and put your new and older crank in. Then you'll know if it works. Though I suspect your shifting on the front won't quite be right. And that fix will involve a front DR compatible with the old crank and a old STI that will cost as much as your old crank you bought.
The cable pull ratio of the STI's are different between 4700 10 speed and the older 10 speed and earlier stuff. 4700 stuff is compatible for the most part with the 11 speed Shimano group sets. Though there are some things that won't go together.
But if the chain ring spacing is the same between the two cranks then you should be good.
Quoted: 514 Post(s)
Liked 448 Times
Yes. The cable pull rates on the shifters are different, but there is no reason for chainring spacing to be different. They both use the same 10-speed chains. Here's the caveat--I never tried this and I never measured. But Shimap nhasn't touched the dimensions of 10-speed chainrings from the 5600-6600-7800 series through the 5700-6700-7900 series, plus Tiagra 4600, and I've heard of many using 11-speed cranks successfully on older older 10-speed drivetrains. So it's highly unlikely that spacing was changed for 4700.
FWIW I put an 11sp 105 crank onto a bike that was otherwise 105 9sp and used a 10sp chain with it. I also put an 11sp 105 FD on it because the new frame had a braze on but the old frame was clamp on. I had swapped all the other parts over. The bike is dead silent and shifts perfectly.
Thanks for the info
Liked 4,810 Times
However the other statements I made might be useful for consideration in other things you might have crop up in your DIY future needs.
