7-speed cassette on 10-speed hub "wobbling"
Hello all,
I am trying to use a brand new 7-speed cassette on a 9/10/11-speed wheel, for my old Cannondale that has a 7-speed drivetrain. Wheel is a brand new Shimano RS010 wheelset. It is listed as a 9/10/11 speed wheelset / hub.
Now i am trying to install a Shimano HG-41 7-speed cassette on it: https://www.jensonusa.com/Shimano-HG...Speed-Cassette
I am using a 4.5mm spacer from "Problem Solvers" as I have read this is the correct spacer to use to go from 7-speed cassette to 10-speed hub: https://www.treefortbikes.com/Proble...d-Alloy-Spacer
Now when I install the cassette using this spacer, after tightening the lockring down, and spinning the cassette, there is a significant "wobble" from side to side (couple of mm). Meaning it is not sitting perfectly straight on there.
What could be causing this? All parts are brand new. Am I using the wrong spacer? Is the lockring not tight enough? Is the hub messed up? (I used this wheel with a 10-speed cassette briefly, and it seemed fine). The cassette only goes onto the hub one way, so I am sure that is right.
Thank you!
Thank you!
Quoted: 76 Post(s)
Liked 19 Times
This is just a guess, but make sure the spacer meets the rivets that hold the cassette together squarely. You might end up notching the spacer to clear the rivets.
I have tried with both this extra 1.85mm spacer and without, but I see the wobble in both cases. I do see that this spacer has some "indentations" on it, perhaps those are not seated correctly or something?
Should the 1.85mm spacer go closest to the wheel center, or closest to the cassette? Perhaps I put the spacer on upside down?
Thank you!
https://www.evolutioncycles.co.nz/as...iew/186822.jpg
Will look for those when I get home. Thanks!
Quoted: 76 Post(s)
Liked 19 Times
If you look at the back of the cassette you should see 3 rivets the indents should line up with those.
Looks like we were typing at the same time. I haven't messed with a 11 speed setup yet, but I had something similar happen on a 9 speed hub.
Quoted: 883 Post(s)
Liked 823 Times
I've only used 7-speed cassettes on nine-speed hubs, so one spacer installed prior to the cassette. Probably, you need two spacers, but should be able to tell before you install the last cog whether you need more spacers.
High precision comes at a higher cost, so it may be within adequate precision considering the price tag.
the upper pulley float, sideways, is part of an indexed shifting system , so , It compensates
for that little discrepancy..
I believe I put the 1.85mm spacer with indentations at the back, and the flush spacer against the cassette / rivets. That would cause it to wobble because it seems like only 2 rivets stick out.
Thanks so much! I will report back if solved.
Like I said, the hub seems fine ("straight") with a 10-speed cassette I have tried it with. Also, the wobble is really significant, I don't think that would be acceptable even on a cheap wheel.
Thanks
Quoted: 2338 Post(s)
Liked 2,823 Times
best I can tell you could do 7 speed cassette with spacer on 8,9,10 speed but run into issues with 9,10,11
possibly a 4.5 mm space and a 1.85 spacer.... .
but in any event this is going to be a kludge and probably have on going issues...... too big a technology gap
Liked 2,823 Times
another think to consider is that your bike is 99.99% 126 mm spacing and the 9/10/11 is 130...... there is a wide variety of opinion on whether you should put a 130 in an aluminum 126......
Not sure if it is bad for the frame, but i can just "bend" the rear triangle apart a bit when fitting the rear wheel. Seems to work fine.
EDIT: There seems to be a thread about this here: https://www.bikeforums.net/classic-v...r-spacing.html
Seems like others have successfully fit a 130mm into this frame. It really does not take much force at all to bend the frame slightly apart, so I believe it should be fine.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Hello all,
Thank you!
Thank you!
Alternately, if it's possible to swap the freehub body to a 7-speed unit, you could re-dish the wheel and it would be stronger.
The only thing that 4.5mm spacer is good for is wasting opportunity.
Unless you are really attached to your 7-speed shifter, why bother with all this? Put on an 8/9/10/11-speed cassette and a matching shifter and then you won't need to futz with spacers and wobble and everything.
That being said, the wheels I have now are just ready for the junkyard, and I have a cheap 10-speed wheelset lying around, hence the need to convert.
I will probably invest in some really nice 7-speed freewheel wheels down the line, just not at the moment.
Liked 2,823 Times
and it is mentioned in this thread https://www.bikeforums.net/bicycle-m...mm-spacer.html
It was indeed the rivets holding the cassette together! There were only 2 rivets, making the cassette sit lop-sided against the flush 4.5mm spacer. The 1.85mm spacer actually had 3 notches in it for this purpose, so I just made sure the 1.85mm spacer was up against the cassette, and the 4.5mm spacer behind that.
Works like a charm now, everything straight and tight. Hope this info helps someone who has similar issues in the future. Cutting notches in the flush spacer, or taking out the rivets from the cassette would also have worked as alternative solutions, if the 1.85mm spacer did not have notches.
Thanks everyone!
Quoted: 138 Post(s)
Liked 16 Times
How To Install 7 Speed Cassette On 8/9/10 Speed Hub [or 11 Speed]
For future reference, here's a video on the subject.
Just use the wider spacer, or add a 10-to-11 spacer, to make the video apply to using a seven speed cassette with an 11 speed hub.
This is true, but I have been running a 130mm rear wheel for about 4 years now on this bike (I do believe it is 126mm spacing). Never had any problems.
not sure what Cannondale u have but I have a older one that has downtube shifters and if your bike has the same u can run it in friction mode and use a 8 speed cassette I have done this with hed Ardenne rims and spacing is 126 but rim is 130 and shifts perfect also just used one spacer that was supplied with the rim
I live in a rolling hilly area, so constantly shifting up, down, up, down again. I would hate to do that with friction shifters.
Liked 2,823 Times
Just a quick update: You were both right.
Thanks everyone!
Thanks everyone!
jhatfie
Bicycle Mechanics
8
10-09-15 04:14 PM
nickw
Bicycle Mechanics
18
03-09-15 07:07 PM
wilber.71
Bicycle Mechanics
4
06-27-10 09:29 AM
