Cracked bearing on Suntour / Kajita Vx Bottom bracket - can I pull and replace?
Quoted: 157 Post(s)
Liked 17 Times
Hi folks - I have what's close to a NOS Suntour / Kajita bottom bracket I was intending to use with a Sugino AT triple (not an easy crank to find a BB for, and the adjustability of this makes it ideal) - - until, upon disassembling it to refresh the grease, I discovered the drive side bearing has a crack in the bearing housing. Looking for some advice on possibly replacing the bearing - how I might pull it, type of bearing puller necessary... I haven't much experience with sealed units like this - I usually am dealing with cup and cone systems, so please assume I know nothing about how to pull it or install a new one. Any advice / tips appreciated. I don't mind the work and would prefer to stick with this unit.
Crack from side
With dust shield removed
Side view
Assembled - just for identification purposes
Crack from side
Side view
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 348 Times
Aside from the asinine proprietary cup pattern, these are pretty nice bottom brackets. The bearings, I believe, just slide on and are stopped by a circlip. If they're stuck, it may just be some old grease gummed up in there; maybe a squirt of WD-40 should loosen up that grease and you can pull the bearing out. If that doesn't work, I would lightly tap the spindle with a hammer while supporting the bearing, that my free it up.
Stolen photo from an eBay ad. There should be nothing preventing the removal of the bearing, really. Probably just needs some gentle coaxing.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Identify the bearing from the text on the seal, then remove the outer race using force/prying to open the crack.
Remove the ball retainer and blast the inner race with a pencil-tip propane torch which will expand it probably within ten seconds so it will slide off.
Maybe first put the other end of the spindle in the vise, I think it will best grab the rounded corners better than the tapered flats.
The new bearing should be driven on so as to fully compress the load path between the two inner races, not the outer races.
Warming up the new bearing will ease the fit onto the spindle so the inner race meets the circlip.
What is the length of the VX bb spindle? I recall these were spec'd as OEM with the AT cranks on some Cannondale touring bikes.
Quoted: 157 Post(s)
Liked 17 Times
I'm getting 126 mm on my digital caliper. I think the Sugino cup and cone original to the AT was 127, assymetrical. I sized the VX up with the crank and frame without fully installing it and it looks like it would work. So you're saying pry off the outer race, destroying it, and remove the balls and retainer, then heat up the inner race so it should pull right off. Guess I'll have to get a pencil tip propane torch. Any chance a soldering iron with a flattened tip would do the trick? Not 100% clear what you mean by using the vice on the rounded tips of the spindle taper - I want to be careful not to bugger up the taper.
Quoted: 157 Post(s)
Liked 17 Times
Likes For msl109:
Quoted: 157 Post(s)
Liked 17 Times
40.
Likes For msl109:
Quoted: 157 Post(s)
Liked 17 Times
Bearing is an IKS 6903 RSP. Can't find an exact match with the RSP suffix but it seems all the 6903s are dimensionally the same. Opportunity for an upgrade, I suppose. Just not sure what's most appropriate for a bottom bracket application. There are ceramics, roller bearings...
Reads 6903RSP
Reads 6903RSP
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
They don't address RSP specifically, but it has do do with the seal. The 6903 refers to the bearing size. https://www.pinkbike.com/news/To-the...ings-2013.html
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
after a hundred years of working in the industrial bearing industry(not quite) my guess is it means Rubber Seal P??
Is the P possibly a damaged R ?
RSR is standard bearing seal designation for japanese etc bearings .
6903 is a pretty standard industrial size deep groove ball bearing .
Quoted: 157 Post(s)
Liked 17 Times
Any suggestions for replacement? Looks like Enduro has some good options, SKB look a bit pricey. Would roller bearings be appropriate, maybe less likely to develop wear over time? I confess to a shamefully limited knowledge of bearing technology and applications.
Quoted: 157 Post(s)
Liked 17 Times
Quoted: 283 Post(s)
Liked 636 Times
Appreciate your reply - It looks the same on both sides, and I looked pretty carefully - the bottom bracket had next to no use, so I doubt both sides would have a damaged B. But it is a single seal, not a double, which I understand would be designated 2RB.
The P may reference the rubber material of seal ?
Some manufacturers used different material for different applications .
You would struggle to get a roller bering that size with seals .
Stick with the existing bearing type . .
NSK or NTN were good brands BITD . They also both do a good full contact seal that would be good for a BB
Suffix for the contact seals is LLU (NTN) or DDU(NSK)
SKF also manufacture that series . Their numbering is slightly different . They will call it a 61903-2RSR .
Quoted: 157 Post(s)
Liked 17 Times
Hi yep - RSR (or similar) relates to one side sealed . 2RSR = both sides of bearing sealed .
Quoted: 283 Post(s)
Liked 636 Times
P = PLAIN one side only sealed ?
Why leave the inner seal out ? Not like you can grease it without taking it apart
Agree you should put a double sealed one in .
Quoted: 157 Post(s)
Liked 17 Times
I think you've got it. It does indeed look like it's single sided - can't think of a reason they'd do that deliberately. I suppose in 1983 it was a big deal to have any seals.
They probably did it for cost savings. A few extra bucks doesn't seem like a big deal on your example when you'll install it and get another 30 years out of it, but they probably had cost pressure across mass manufacturing scale.
Yesterday I replaced the original serpentine belt in my 12 year old car. The best price I could find on the OEM part was $13. I opted for the premium one that was $35, which was _almost_ the most expensive one I could find. There was a small discount over the most expensive one.
If I'm going to bruise and dirty my arms, I might as well put something in that'll last until it goes to the junk yard. Still whines like an SOB, though, so now I have to figure out where the next component replacement is...
Quoted: 157 Post(s)
Liked 17 Times
Liked 1,296 Times
The inner seal wouldn't do anything useful since the shell of the cartridge keeps that side completely enclosed.
An inner seal only adds drag, weight and cost, however slight.
Quoted: 157 Post(s)
Liked 17 Times
But the shell of the cartridge isn't sealed, and a rainshower or two is all you need to start water seeping down the seat tube, no? It's why so many bottom brackets are coated with rust and why BB shells are often drilled out.
mycocyclist
Quoted: 910 Post(s)
Liked 822 Times
Gestalt
When the cups are seated against the O-rings on the shell of the unit, there is no way for water to enter from "inside" the frame.
(Have a few of these and favour them. They are unsung inexpensive alternatives to what is essentially the same Phil option.)
Quoted: 157 Post(s)
Liked 17 Times
Got you. That makes sense. So there's really no need for a double seal. The O rings seem soft and in good shape. The unit is really well done, and I'd agree, more or less on par with Phil for a fraction of the cost.
Likes For msl109:
Liked 1,296 Times
I'd guess that Suntour had these made by Sugino.
Quoted: 157 Post(s)
Liked 17 Times
I believe it was Kajita, actually. Sugino made many (all?) of their cranks and probably a lot of their BB's, but this unit is identical for the most part to sealed Kajita units called "Runner" and Runner Pro (which had a hollow axle) I'll clip a pic if I can find one.
Quoted: 157 Post(s)
Liked 17 Times
I had mistitled the post, it's Kajita, not Takagi. Will try to get it changed. Here's a pic of the standard Kajita, lifted from an online ad. Suntour apparently had custom specs for theirs, PARTICULARLY the proprietary notches for which they sold a specialized tool - and now we must improvise.. .
