Sheepish question
Quoted: 8 Post(s)
Sheepish question
Hello,
Someone earlier today mentioned that it might be an idea to fiddle a bit with the tilt of my saddle. I haven't touched anything to do with the saddle except the overall height since I bough it. He said it might be tilted too far up at the front. So I am asking for help since I am not really sure how to adjust it.
So, I had a look at the saddle and underneath there is a vertical bolt but it seems to only adjust it forwards and backwards as a whole, and not adjust the tilt. Am I missing something here? I don't know and couldn't find the model of the saddle but it is the basic Bontrager one that comes with most of the lower end Trek recreational MTBs.
Thanks
Thanks
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
Originally Posted by damnable
Hello,
Thanks
Thanks
See also my article on saddles and saddle adjustment:
https://sheldonbrown.com/saddles
Note, the bolt needs to be nice and tight to keep the parts from slipping. The threads of the bolt should have a coating of grease on them, and also the underside of the bolt head.
Sheldon "Laprade" Brown
Code:
+------------------------------------------------------+ | A billion here, a couple of billion there -- | | first thing you know it adds up to be real money. | | --Sen. Everett McKinley Dirksen | +------------------------------------------------------+
Quoted: 1572 Post(s)
Liked 644 Times
Originally Posted by Sheldon Brown
That bolt holds two curved pieces together, one is the top of the seatpost, the other is the part that the saddle rails sit on. If you loosen the bolt enough you can move the upper part forward or backward to adjust the angle. The curved surfaces have teeth in them to keep them from slipping, so you may need to loosen the bolt a fair amount, and even lift the upper part to disengage the teeth.
Code:
If you have a problem with this adjustment, it's usually because the upper part of the clamp hasn't separated from the saddle rails. When that happens, it'll let you adjust the saddle tilt but, when you retighten the bolt, it'll go right back to where it was.
Hypoxic Member
Also notice the position of the rails relative to the clamp so you know
what you are used to fore & aft. Often the rails are calibrated. When
you loosen the clamp it will move.
Prefers Cicero
In terms of what tilt to aim for, most people seem to have their saddle dead level or very slightly tilted up at front. If it tilts down at front you tend to slide forward so the narrow part of the saddle digs into your crotch, and you put more pressure on your hands or wrists to hold you back. If it tilts slightly up at front, that helps keep you back on the wide part of the saddle where your ischial tuberosities (sit bones) can carry your weight. Too much uphill tilt and you start to crush "the boys".
I am not a deer
Bikes: 1987 Centurion Ironman Master, 1984 Fuji touring series IV
Originally Posted by knewbike
Not to be contrary but I like mine tilted a degree or 2 down . I have to have NO pressure on my prostate so I combine this with a split nose design Koobi. Otherwise after a couple of hours I will leak . Mind this is a very slight angle so I have no problems slipping down the seat.
Quoted: 8 Post(s)
Thankyou Professor Brown and very helpful members. Adjusted it today and will take out a few times to see how it goes. From what I have read, most women seem to be better off with saddles other than the stock ones. (Yes, I am a woman, so I don't have to worry about "the boys", but that doesn't mean it doesn't get uncomfortable).
Bikes: Cannondale R-4000, Cannondale R-400, Nishiki Road, Kestrel 4000, Cannondale mtn
I have my Brooks saddle leveled, but the nose of the saddle pointed ever so slightly to the left. This set up is quite comfortable. I'm not sure why, but maybe "Richard and The Boys" are kinda leaning to the right side of my anatomy.
Enjoy
Bikes: Trek 5200
Liked 5 Times
