Is a silent bike a faster bike?
My bike is dead silent, and my friend's makes all kind of noise. We were talking, and I said that a quiet bike is more efficient, and he said it probably doesn't make a whiff of difference. Now we're talking probably 1% efficiency or less, but does it really matter?
What kind of noise? If it's a squealing crankset, for example, that's robbing energy from the rider. But from hubs as you coast? Some of the smoothest/expensive hubs out there are quite loud. Chris King hubs come to mind, but that's understood as bicycle purring.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Yes, except for hubs. Noisy freewheeling hubs offer a greater speed benefit than painting your bike red.
Bikes: 2017 Specilized Roubaix, 2012 Scott CR1 Team, Felt Z85
Quoted: 26 Post(s)
I think I go faster when my bike is stealthy quiet. No data to support this of course.
Technically, yes... noise is a wave an waves have energy, that energy needs to come from somewhere, vibrations generally from friction. Friction = bad for speed. How much speed? Well, that depends on what is causing the noise, wavelength or frequency (pitch) and amplitude or loudness. the higher the frequency the more energy it holds, the louder it is, the more energy it holds. Thus a loud high pitch noise decreases your forward motion more than a a quiet low pitch noise (with no external variables, and on a bike, well... there are a ton of other variables). So to answer your question..... it depends!
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Frame materials carry sounds differently as well. I've got the same group on a steel and a CF both with essentially the same geometry and wheels. The CF is nosier. I had an Al bike as well which really was loud
SuperGimp
If my bike is making noises, i'm constantly shifting around looking for the source, so yes - a noisy bike is slower (for me)
toasty!
Bikes: 1998 Cannondale r200, 2011 Bianchi Via Nirone 7; 2007 Redline Conquest Pro
I like my bikes to be as quiet as those old Rolls-Royce commercials.
That being said, my rear derailleur seems to be making a purring noise from the pulley/jockey wheelset. My mechanic tells me that's how a 'real' derailleur is supposed to sound, as my current piece has sealed bearings in it, as opposed to the setup I'm used to seeing in my old Sora derailleurs.
Bikes: 2011 Trek Rumblefish (FS)
Bikes: Felt F1C
The Red components on my tribike are audibly loud. It's actually really nice. The shifters have a solid "CLICK". The chain is this steady bbbbbbbbbbbbbbbbbbbbbbbbb. And when my cadence is perfect at its maximum efficiency (about 105-110; any more, I start bobbing and I'll shift up), there's a change in the sound to a loud BBBBBBBBBBBBBBBBBBBBBBBB from the cassette/wheel/chain combo. Friends can hear me rushing up
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
I don't think it makes any difference, but if my bike is creaking it does tend to make me ease off a little either in an attempt to minimize the noise or in the highly unlikely event that something breaks. It's all in the mind.
BF, in a nutshell
BF, in a nutshell
Administrator
Liked 2,180 Times
Me on my bike with carbon wheels
Absolutely! For several reasons.
1) With a noisy bike I am constantly pausing, trying to figure out where the noise is coming and thus reducing my speed.
2) Witha noisy bike I am less likely to ride- the ultimate in slowness.
3) Drive train noise = friction = speed reduction.
Not so sure 3 makes much of a difference but no question 1 and 2 do.
Business Man
Bikes: Cannondale Supersix Evo Hi-Mod, Soma Rush
Aside from the whoosh of the tires on the road, and the clicking of the freewheel, a bicycle should be silent.
-Sheldon Brown
-Sheldon Brown
Quoted: 551 Post(s)
Liked 278 Times
If your hub is making noise, that is your HTFU alarm activating. It means you stopped pedaling, and this actually means you are slowing down!
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
Good question. My Merlin Ti with Record 10 is super quite. My Orbea with Chorus 11 is not so quiet for some reason.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
The more upgrades I do the quieter my bike gets.. food for thought.
I have some drive train noise when in the big chain ring, but not in the small chainring. Nothing really annoying but just slight constant, what appears to be, chain noise.
Just can't figure it out. Any suggestions?
Administrator
Liked 2,180 Times
Quoted: 1186 Post(s)
Liked 289 Times
Check your rear derailleur hanger alignment. Also, make sure your derailleur is adjusted properly. If you pull on the rear shifter cable while riding you can change gears and hear the effects of fine adjustments on the noise.
If the noise is due to friction from anything aside from the derailer/freewheel, then yea, that friction is slowing you down.
Mentally though, a quieter bike seems faster for me, mainly due to the fact that whenever my bike does make noise, something is not right :/
If you want quiet, I'd suggest a 105 rear derailer. At 15+ the only thing's I hear are the rubber hitting the pavement.
Quoted: 1529 Post(s)
Liked 718 Times
Mmm, silence.
Well, you are pulling more chain with each rev.
