Replacement Nuovo Record cones 25R
Quoted: 1608 Post(s)
Liked 2,216 Times
Overhauled a front HF hub yesterday and discovered that both cones are pitted.
I did a search but it is about timing. Posts form 2016 are not helpful when the supplier is gone
What is the recommended practice for replacing cones for either the front or back nuovo record hubs?
Did I read on some thread of using sealed bearings to replace the cup and cone?
Quoted: 1106 Post(s)
Liked 1,328 Times
Once they are pitted they are replace items (just like headset races). Although fully hardened so it is possible to regrind them, you need specialist equipment to do so - ball tolerances are on the order of millionths-of-an-inch; it is extremely unlikely that a home-shop attempt will get cones all three of smooth, round, and concentric (never mind getting the curve right so the ball contact-angle does not change).
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
There's some on eBay, not "Record" but NOS and compatible. Seller says at least 10 available:
https://www.ebay.com/itm/29518969169...Bk9SR6D6w5P8YA
Liked 2,216 Times
@JohnDThompson,- Couldn't verify compatibility, Thanks! Ordered.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
I've used Ofmega cones to replace 25R in a Record front hub.
They are still working fine after 1k miles.
Likes For Aardwolf:
Chorus, being a descendant of the Nuovo Tipo hub have 3/16 balls in the front hub.
Liked 2,216 Times
So does 1/32 drive incompatibility?
Is there another choice?
Old fart
Liked 3,400 Times
Liked 2,216 Times
0 for 2
