Light mount for side of fork
Quoted: 7359 Post(s)
Liked 2,502 Times
These used to be available commercially. Does anyone know of a source. The pictures in this album of my homemade solution. I want a peg mounted on the side of a fork onto which I can mount a light. I want this location because the handlebar and fork crown are occupied and unavailable.
Quoted: 1226 Post(s)
Liked 635 Times
Same here, subscribing for any ideas. My fancy new carbon gravel bike has a mount on the fork close to where yours is located.
Quoted: 48 Post(s)
Liked 10 Times
I can't see in your photo if your fork has mid fork rack mounts. If it has them the Paul Gino mount is nice https://www.paulcomp.com/shop/compon...o-light-mount/
Quoted: 2333 Post(s)
Liked 2,097 Times
Chronometer NOB?
Maybe not the most elegant but they work well.
https://www.peterwhitecycles.com/accessories.php#nob
Quoted: 2614 Post(s)
Liked 1,960 Times
Problem Solvers has a solution: Universal Cycles -- Problem Solvers Braze-On Light Mount [LT0902]
Note some of the commercial solutions are a bit under-sized for some mounts.
Liked 2,502 Times
I think the Problem Solvers item is too expensive and needs a boss to screw into. My fork has none. The Nob on the Peter White site looks good, but he doesn't have an order page, and it's out of stock (and probably production) everywhere else, so maybe it's also out of Peter White's stock.
Quoted: 3483 Post(s)
Liked 1,481 Times
If Amazon does not have it, I do not know who would
https://www.amazon.com/Minoura-Light...dp/B001D11ENC/
Quoted: 5234 Post(s)
Liked 3,602 Times
I put these on my wish list a cpl years ago but never bought any of them, but I see now you don't want to screw into anything, sorry
M-Wave Quick Release Light Holder
Paul Component Gino Light Mount, Black
Paul Components Gino Light Mount
KCNC 2013 Light_Mounting_Bracket_for_QR_Skewer_Hubs
Liked 3,602 Times
this place has t-connectors +
Likes For rumrunn6:
Liked 3,602 Times
Tubus LM1 Fork Adapter - mounting set for forks without eyelets #72100 ???
these things?
https://twistedthrottle.com/shop/lig...s-black-rev06/
https://www.amazon.com/PIAA-74000-1-...48897152&psc=1
seems like the motorcycle world has tried to tackle the same challenge, but they have round forks
these things?
Liked 2,502 Times
That's all good stuff, @rumrunn6. Thanks. I especially like the Tubus gadget because I've seen racks I'd like to put on though my forks don't have bosses. I might use that gadget for adding a rack. Given that all these ideas are expensiver than my homemade gadget, I'll keep making it. I've made it out of PVC pipe as well as copper pipe. Interestingly, I make them without using any rulers or other measuring tools. One of the hard and fun parts is mitering the pipe to fit the curvature of the fork. I just use a round file and keep checking the fit.
Likes For noglider:
Quoted: 4846 Post(s)
Liked 3,976 Times
I have a pair but I am unwilling to torch off the attached Mooney. Peter brazed them on low as LowRider mounts. At that time he was unwilling to drill fork blades. Convincing a fork failure survivor wasn't hard! (We were clubmates when it broke. He almost certainly was at the annual club dinner 5 days later when it was announced I was in a coma.)
Great rack bosses! Only drawbacks - a little wider and slightly spread most racks and I have to drill or file the rack holes to fit the larger bolts.
Likes For 79pmooney:
Liked 2,502 Times
Yes, the light in my pictures is a German-law-compliant light with a very asymmetrical beam shape.
Liked 1,481 Times
I generally do not suggest that you mount a light lower than you have used it. I have it lower on my errand bike against my generic recomendation, but I only ride that bike for short distances and then only on well lit streets. I use the light on my errand bike more as a to-be-seen light, not so much to-see-with light. And I get large shadows from small stuff on the road like leaves.
But that is an option if you want to try it. I used a threaded rod in the fender mount on the dropout. Or, you could use one of the skewer mounts cited above on a skewer, or some combination of that.
I got the dynohub wheel for cheap from a bike charity, the vintage light was a bottle generator version (no switch) that was sitting on my shelf unused. Otherwise I would not be investing in a dynohub for an errand bike.
The light does get in the way on some bike racks that are designed for you to put a front wheel into the rack.
If the light is for commuting on roads that you travel on frequently, mounting it low like that might work well for you because you know the road well, then the large shadows are less of an issue.
This is the easiest wiring job I have ever done, the light was grounded to the mount, the Shimano hub is grounded to the fork, I only needed a single conductor wire, less than a foot long. Light is always on.
Likes For Tourist in MSN:
Quoted: 4286 Post(s)
Liked 1,377 Times
And, for many cycling-specific lights, the beam has a cut-off at the top and floods horizontally below the cut-off. Orienting these lights by 90' would mean all that engineering wouldn't do much for you.
Liked 2,502 Times
@prj71, perhaps you need to look at a shaped beam to see what it's like. If it's sideways or upside down, it's extremely ineffective. And I'm not asking how I can eliminate the mount I already have and works well. I'm asking if such a thing is commercially available because it works so well for what I need. So I think you're underthinking it, i.e. offering a solution to a problem different than the one I have. If I ask you what the weather is and you tell me what time it is, it doesn't matter how precise your time readout is.
Likes For noglider:
Liked 2,502 Times
@Tourist in MSN, yes, on one bike, I have a special "nut" on my QR skewer that is big enough to mount a headlight. As you say, when it's that low, aiming it is tricky. I manage to get it to work, but it's less than ideal. The ideal height for a bike headlight on a bike with 700c wheels is somewhere between the fork crown and the handlebar.
mosquito rancher
