3D Print Wheel Trueing Gadget
Quoted: 970 Post(s)
Liked 1,632 Times
This little device just mounts to your seat tube via rubber bands. You can then check and adjust the true of your rear wheel using coat hanger wires inserted into the holes. If interested I posted the file in Thingiverse under "Bicycle Wheel Trueing Device". I use heavy duty coat hangers at 2.6mm diameter, so if you need the design modified to take another size coat hanger let me know.
https://www.thingiverse.com/thing:5282097
Likes For zandoval:
Bikes: Salsa Fargo Ti, Cannondale CAAD9, Carbonello Fixed Gear, Specialized Epic Disc
Quoted: 39 Post(s)
Liked 16 Times
A zip tie on the seat stay works about the same.
Ride it like you stole it
This is very clever, I like it. Technically you would only need one bent rod. If your wheel is not bent then truing to one side should be enough, you could always remount it upside down the check the other side. That way you could make it smaller and maybe faster to print.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
Likes For WheresWaldo:
