Weight Threshold for Rolf Vector Comp?
I'm about 200lbs and thinking about running a Rolf Vector Comp for a front wheel. Does anyone know how much weight they can handle? I usually frequent the SS/Fixed forum but figured I'd get an easier answer around here. Thanks.
Making a kilometer blurry
Those Vector Comps are heavy training wheels with no weight limit. They are durable.
Ninja don't wear flipflop
Bikes: Specialized S-Works Roubaix SL3, BMC TM01...if it every ships
I had one for years when I was 240+. Mine was indestructable.
First off, aerodynamic properties matter a fair amount, so really deep rims are better (neither V. Comps or Ksyriums are aero). To get reasonable aero improvements, you're going to need a 40mm or greater rim depth. So, AC420s, Zipps, Reynolds, PlanetX, Lews, etc., etc. are all more aero).
Weight is highly overrated. Rotating mass barely matters at all. Raw weight uphill is well understood. If you and the bike weigh 175 lbs, how much difference do you think 200g makes? Yeah, it's that simple.
You want a stiff wheel so you don't get brake rub or goofy handling. Ksyriums are probably stiffer than the V Comps because of a smarter lacing strategy -- at least on the rear. They're possibly as durable.
Physics
I had to create an account, just to leave a response to the self assure "comprehensive response" that you left.
Pretend you don't know anything about physics...shouldn't be hard, because you don't.
Ask yourself: "Why do car manufacturers keep trying to make lighter and lighter wheels?!" Do you think that a pound in the car matters? Why do car makers use terms such as: unsprung weight?
Well, turns out that spinning up weight, and centrifugal force are heck of a lot different than just dead weight...yes, this requires some rudimentary understanding of physics.
Or just take my word for it: you are dead wrong! Now go out and research stuff before you post garbage online...please!
Also: Rolf Vector Comps are a heavy, but a very rugged wheel. I had mine for 18 years now, and I had to repack the bearings once.
Shhh. Don't tell anyone on BF, but there's not too much performance difference in wheels (by "better," I'm assuming you mean "faster". Correct me if I'm wrong.
You want a stiff wheel so you don't get brake rub or goofy handling. Ksyriums are probably stiffer than the V Comps because of a smarter lacing strategy -- at least on the rear. They're possibly as durable.[/QUOTE]
Quoted: 645 Post(s)
Liked 797 Times
I ran Vector Pros (same paired spoke design, fewer spokes (14F, 16R)) for ~16 years/~50,000 miles. I'm 185 lb. They were completely bulletproof. The only potential downside with this design is if you break a spoke, the wheel will go significantly - even possibly unrideably - out of true
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,926 Times
Likes For datlas:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Damn, you really put a lot of thought into a post that's only a little over 14 years late.
Likes For cxwrench:
Quoted: 3241 Post(s)
Liked 2,512 Times
Was it a question on wait threshold? Maybe that explains it.
Liked 8,926 Times
No prob dude. I have suggested many times to management that an old thread like this should not be able to be bumped except maybe by the OP or someone else who posted, but apparently that's not realistic.
Liked 8,926 Times
Likes For datlas:
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
You got me there.................
I don't know...............
I'll be damned.
I'll be damned.
