Replacement for Shimano Acera M391 brake+shifter unit (9 speed)
Quoted: 13 Post(s)
The Shimano rear shifter on my hybrid seems to be worn in that the gears don't change well any more, and haven't done even after replacing the cable. The shifter and V-brake is a single unit. It seems peculiarly hard to get a replacement integrated unit. Any ideas? Do I get separate shifter and V-brake, taking to account there is precious zero space left on the handlebars? And which Shimano range - there is Deore, CUES, Acera, EZ Fires Plus, but some of these I read are being discontinued? I have no idea which is decent, I certainly don't want worse than the existing Acera brake/shifter and Deore derailleur that I have.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,474 Times
Likes For SoSmellyAir:
Quoted: 13 Post(s)
just the cable, although the housing was replaced a couple of years ago too. the shifting just seem to be getting slowly worse, hence my suspicion that the shifter is wearing (if they actually do wear?). I am happy to replace it. Just seems hard to find something equivalent with a built in brake lever
Really Old Senior Member
It doesn't have to be Acera, just Shimano compatible for hybrid/MB.
https://www.amazon.com/SHIMANO-ST-EF...11691650&psc=1
Quoted: 13 Post(s)
The Acera on my hybrid has been working fine for the last 11 years, but if you want to make it difficult on yourself, be my guest.
Quoted: 13 Post(s)
I've also had my Trek 7.4 for 11 years, but the gears seem to have been struggling for a while now, despite regular new cassettes / chains etc
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
I had a good experience with Sunrace ST-M930 (it was paired with Tiagra 4603 RD).
Not experienced with MTB components at all. But the ST-EF510 appears to be what you might be looking for - Acera-level, 9-speed, and the DM says they "are equipped with a mechanism to make them compatible with V-BRAKE brakes, which contain a power modulator, cantilever and roller brakes."
https://bike.shimano.com/en-EU/produ...F510-9R2A.html
The older ST-EF65 (9-speed version) might also be workable, and is still available from some sources. I believe (but won't swear) that those are also V-Brake compatible.
Likes For Hondo6:
Liked 739 Times
Sorry but I'm very much learning my way here and certainly don't want to make things difficult! The listing doesn't seem to say in the description that it's V-brakes and in the questions someone says it is definitely not V-brakes.
the problem is USUALLY old, stiff, grease making the tiny parts in the shifter get stuck to each other...
PS.. i just now completed this "repair" to a 3x8 shifter/brake pair... the 3x side was not working at all... i lubed and operated both sides.
i carefully removed the tiny philips screws(do this ONLY over a hard floor surface with no cracks, they Love to get lost!) then i spray the PB blaster into theshift mech... i then carefully move the spring loaded pawls with a tiny screwdriver until they easily move and snap into position by themselves.. i then operate the shifters dozens of times before replacing the cover and those tiny screws that Love to get lost.
TIP: If the shifter cover is on the bottom of an older style brifter or shifter, I loosen and rotate the shifter cover to the TOP before working on it... and i NEVER do this over a cracked, dirt, or gravel surface, or in a dark area where finding those Expert Hider screws will be impossible if they get dropped..
Likes For maddog34:
Liked 1,474 Times
Shimano Altus ST-EF505-9R 9-Speed Right EZ-Fire Plus Shift/Brake Lever for Hydraulic Disc Brake, Black - Modern Bike
However, this one is Acera and for B-brakes:
Shimano Acera ST-EF65-9R 9-Speed Right EZ-Fire Plus Shift | Components | Shimano | PlanetCyclery.com
drb01 may be right; the one linked by Bill Kapaun appears to be for hydraulic brakes:
In limited experience, I found the EF-65's shift a little more precise vs the EF-51's.
A canti braked version also works with V brakes. I've not seen a canti braked only version.
Likes For Bill Kapaun:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
May I ask as to why you're going back to brifters?
Why not just buy a shifter and then use a brake lever of your choice?
https://www.ebay.com/itm/363825624242?
Buy a pair.
Buy a pair.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
This is the set up I have going on on my 1x9 (work in progress)
I can run the shifters need with the levers I prefer.
Quoted: 13 Post(s)
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
https://bike.shimano.com/en-EU/produ...0/BL-4700.html
