openbuild-approach for creating a (mini- workbench) lathe ...made out of 80/20
hello dear community
hi there - dear friends
one little question regading the toolset:
found some interesting ideas regarding the tools : an openbuild-approach for creating a (mini- workbench) lathe ...
i need a mill and a lathe found the openbuild-approach and like it very much - well there are several nice things out there
https://openbuilds.com/?id=297 CNC LATHE BUILDS | OpenBuilds
and this interesting thread: 80/20 benchtop lathe build
https://www.cnczone.com/forums/verti...1-cnc-cad.html
and just see the images
80/20 benchtop lathe build https://www.cnczone.com/forums/verti...40584-cnc.html A benchtop cnc lathe build
Default DIY benchtop mill build https://www.cnczone.com/forums/bench...ill-build.html DIY benchtop mill build
btw: regarding the Bike-Frame-building - see the frame-jig - that is designed by thanner w and made public here - it is build in 80/20 Extrusion .. see Bicycle Frame Building Jig
well i am interested in all thing openbuilds - and look f orward to a fruitful discussion - are there any approaches for the lathe (a work bench lathe ) ... out of 80/20 and perhaps a mill ... etc. out of 80/20
Look forward to the discussion
update: btw found this - which is very sophisticated
Lathe 4" x 40" https://openbuilds.com/builds/lathe-4-x-40.2678/
see the mini-mill:
https://openbuilds.com/builds/openbuilds-minimill.5087/
OPEN SOURCE - The MiniMill machine is Open Source and the Builder community is encouraged to modify and build on this design.
EASY TO BUILD - With the V-Slot Modular Framing System and OpenBuilds Build-Along Video, assembly is quick and easy.
AFFORDABLE - OpenBuilds budget friendly parts allow Builders the opportunity to freely create.
CUSTOMIZATION - Take it to the next level and make it your own! Share your builds with the Open Source Builders community OpenBuilds.com
Well I had such good luck building a mill using good parts with 80/20, that I have decided to go the same route for a small production lathe. I did convert a 7-12, but with less than stellar results. It is the backlash, general flexing, lack of motor power that directed me to just build new, rather than try to upgrade the 7-12. It is a much better manual lathe than it is on cnc with stock parts. ........
see the mini-mill:
