Will my V-BRAKE/ SHIFT LEVERS fit on a drop bar ?
Will my V-BRAKE/ SHIFT LEVERS fit on a dropbar ?
Dropbar -
https://www.pinkbike.com/product/wtb/...Road-Drop-Bar/
V-brake/ shift levers -
https://cambriabike.com/Images/produc...8_shifters.jpg
My bike-
https://www.dickssportinggoods.com/pr...ductId=3443177
Front disc brake back is direct pull
I just want to change the handlebar and keep the Brake/shift lever.
Thanks,
CK
My bike-
Thanks,
CK
DancesWithSUVs
Quoted: 7 Post(s)
Maybe. If you get the 25.4 you might be able to get the controls around the curves. FYI,a trekking/butterfly bar will be cheaper,will def be compatible with your stock controls and stem,and will give you multiple hand positions with the ability to get aero.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
+ 1 on the bars at www.nashbar.com (& others) as per 2 fellows I read 2 years ago. That bar provides LOTS of hand possitions an can be mounted a few dif. ways.
Bianchi Goddess
Quoted: 2934 Post(s)
Liked 2,930 Times
is 25.4 the diameter of the bar for the entire length or just at the clamp area?
Sugar "Kane" Kowalczyk
I have made mountain shifters fit a that bar with a file, but didn't like the fit. Eventually went to bar end shifters and cane creek scr 5 levers because of the disc v brake combo I am running.
DancesWithSUVs
Quoted: 7 Post(s)
Nashbar usually carries them under the name 'trekking bar'. Google for more choices.
https://www.wallbike.com/components/handlebars.html
Here is a site that carries them. Butterfly bars or trekking bars.
STFD
Bikes: '80 Windsor Carrera Sport, '02 Specialized Sirrus A1, '10 Giant Escape 2
25.4 mm (1") is the clamp diameter. Beyond the clamp area, bars taper to 7/8" (MTB and upright and trekking bars, many bullhorns bars) or 15/16" (most road bars, some bullhorns). Your MTB brake/shift levers will probably not work on drop bars. If the clams are aluminum, they probably won't work, though you could take them to a machine shop and mill them out from 7/8 to 15/16. On an older bike with steel clamps, sometimes the clamps will work on 15/16 bars. The OP's bike is newer, though, and probably has aluminum clamps.
But for braking on drop bars, drop bar levers will be more ergonomic anyway. Tektro linear pull (v-brake) levers are $20-25 a pair (does the front disc brake on this bike have the same cable pull as v-brakes?). Changing the shifters is trickier, but there are options.
But the suggestion to get trekking bars instead of drops is a good one, if you want to avoid changing brake levers and shifters.
Looking at the photo of your bike, the bars are pretty high. Depending on what you want, you may want to get a stem with a different angle, or flip the one you have, if your goal is partly to be a bit more aerodynamic.
Crazy ole cat lady
Bikes: One built up on a Nashbar frame, one built up from a Paramount frame
FYI Nashbar has been out of trekking bars for several months. There is nothing on their site about when, if ever, they will be back in stock.
McGreivey, the picture of the OPs bike is a stock shot on the Dick's Sporting Goods site. Its not the actual bike.
