Replacement pedicab tires.
Quoted: 264 Post(s)
Liked 347 Times
Where can I find replacement tires. My friend translated it and said they were tubular, but I doubt it. It is also a very strange size.
Quoted: 4223 Post(s)
Liked 3,914 Times
26 x 1 3/4 is a size that Schwinn used for many decades. what ISO lists as a 571 tire bead seat diameter. Is this the size of your tires? Do know that bicycle tires are not just size specific but also can have casing and tread differences that might be important to consider. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
It looks like they are 26 x 1.75 tires (not tubeless)
If I am right, here is a good deal on a pair
https://www.amazon.com/Kujo-One0One-...8-8&th=1&psc=1
Really Old Senior Member
See Sheldon-
https://www.sheldonbrown.com/tire-sizing.html
Look for 650C or ??-571mm markings as Andy mentioned.
Likes For Bill Kapaun:
SE Wis
Quoted: 2751 Post(s)
Liked 3,408 Times
Likes For dedhed:
I don't know.
Quoted: 321 Post(s)
Liked 869 Times
they do look like they might be tubulars. The rim doesn't look deep enough for a hook and bead. I could be wrong. Or maybe they are S7 (Schwinn) size?
Quoted: 851 Post(s)
Liked 1,082 Times
Here's Sheldon Brown's tire size article. A little bit of a long read but you can just skip to the charts to show what each size is in different measurement systems. ISO sizes are usually the most accurate for finding what will fit your rim and as Andrew mentioned the tires in the photos would be a 571mm BSD (Bead Seat Diameter) ISO size. My guess about the "tubular" reference from the friend is just a mistranslation of a "tubed" or "clincher" tire. Tire Sizing Systems (sheldonbrown.com)
Quoted: 327 Post(s)
Liked 250 Times
Learn something new everyday............
Found this article explaining this issue.
https://thecabe.com/forum/threads/sc...nd-more.78808/
