Kobe Cobra rejuvenation project
Howdy. Judging by this thread, its been a while since I brought up Kobe bicycles around here.
Back then, I wanted to tackle a bike restoration project to renew some faded skills and interests. Well, so much for great intentions. The project languished for three years apparently.
Anyways... Over the past few months I've squirreled away time here and there, and wouldn't you know it? I "finished," the project. Finished in quotes because, is it really ever finished?
I chose the word rejuvenation instead of restoration because I installed some new stuff on there. I wanted new brakes for example. I also wanted a new freewheel. The size in my dropouts is 124mm. Its a very tight squeeze. Not sure I'm completely ok with it, but for now, it works.
I plan to update this thread with a list of all the parts I retained, why, and so forth. I need help and ideas with a couple things too.
For now, here's a link to the pics. I hope you enjoy them.
I think you've done a great job. Looks quite good. Was the paint a powdercoat, rattle can or actual paint?
As fate would have it, in between buying the Kobe and restoring it, I purchased an old Gold Wing. For that project I did the painting myself, including provisioning my garage for the work. So for the next project, if I want to paint, I wouldn't send the job out, and I wouldn't powdercoat it.
Quoted: 3814 Post(s)
Liked 3,345 Times
thanks for posting.
the forum just had a recent Kobe Cobra thread you might like to see also:
https://www.bikeforums.net/classic-vi...serial-no.html
thanks for posting.
On a related note, here's a picture of the left over bits.
Bikes: 1983 Cannondale ST500, 1987 Cannondale SM400 with SA 3 speed hub, 1987 Schwinn Tempo, 1982 Schwinn Voyageur SP, 1992 Kona Explosif
Quoted: 8 Post(s)
Liked 7 Times
Looks really nice, but how do you not slide off that saddle? Makes my hands sore just looking at it.
Bikes: 1980 Kobe Cobra
Where was your serial number located? Still haven't found a definitive number/letter combo to tell me.
Its interesting that you mention / observe this... while I wanted the seating position to be somewhat aggressive, practically slipping forward when mounting is rather too much. It doesn't help that the frame is 54cm and I should be riding a 56. =/ I did two miles on it the other day and yikes. Should I try another seat, or another seat post?
T-Mar sent me a very detailed analysis of Kobe serial #'s. (thanks!) According to his analysis my bike is a ~1977 unit, given the 76.10 on the seat post.
However I thought the 73 following the TA in the serial number meant 1973... ? Would it be possible the frame was made in '73 but not assembled until years later? T-Mar went on to suggest the TA stood for Tano, a manufacturer at the time. Very interesting.
Quoted: 8 Post(s)
Liked 7 Times
I'm no expert on fitting though, try different things and go with what feels right for you.
