Tire Load.
Tire Load.
Old 07-22-14, 10:07 PM
lwik
Quoted: 13 Post(s)
Tire Load.
Quick question. I am looking at tires here: Schwalbe Marathon Plus HS 440 (Wire Bead Tire), Tires / Tubes / Liners, 11100756/772Bicycle Touring & Camping Gear with Forum, Articles, Reviews, Information, Advice, and Tips.+++ and each one has a load capacity in lbs. I was wondering if that is for 1 tire or both? I weight 265 lbs, plus the bike and camping gear. I am assuming it is a rating for just 1 tire. So if it says 220lbs then 2 of them could support up to 440 lbs., right?
Thanks.
lwik is offline
Old 07-22-14, 10:26 PM
prathmann
Quoted: 659 Post(s)
Liked 7 Times in 6 Posts
Only if you have equal loads on the front and rear wheels. Usually the rear wheel of a bicycle has considerably more load on it than the front, but you could help equalize the load if you put your heavier gear in front panniers
prathmann is offline
Old 07-22-14, 10:38 PM
lwik
Quoted: 13 Post(s)
Gotcha, Thanks!
lwik is offline
J.Drop
Bicycle Mechanics
5
06-22-18 09:22 PM
imi
Touring
18
11-24-15 01:15 PM
Tandem Tom
Tandem Cycling
26
04-14-13 10:20 PM
Raim77
17
05-09-11 11:15 AM
fixiedavid
Singlespeed & Fixed Gear
13
03-12-11 03:05 AM
